Hi Guys,
I am about to pull the engine out of my 94' BNR32. Basically I am looking for some advice as to what I have missed given that I am only seeking 250-280rwkw (ands thats in the future not now). I am primarily looking for reliability atm.
So here is what I have:
-water pump
-gates timing belt and new ilder bearings
-new turbos
-new dump pipes
-new silicon heater hose kit
-bought a full engine gasket kit so I can do the gaskets for the plenum.
I think I should get a sump baffle whilst the engine is out. I just cannot decide what one! I have been looking at the tomei one that fits in the standard sump.
Thanks for your input guys.
https://www.sau.com.au/forums/topic/336830-what-have-i-missed/
If you only want 280rwkw then you don't need to change dumps, sump mods.
Also be careful when changing the plenum gasket. I do believe there is a "trick" to get it to seal correctly. Do not clean the butterflies etc either.
Also the silicone heater stuff I've found to be crap. I've had to replace 3 hoses in 1.5years and I've done less than 10,000kms.
It's one of your typical EBAY special's. It's been replaced this time though with Nissan OEM hose :geek:
Cheers Ash - I have a pretty good mechanic, one I actually used to work for at revo, but we'll definately be careful on the plenum. I have heard that the standard gaskets can become very brittle as they age and have a tendency to split (CRD and JustJap told me).
I got a very good price on the dumps so thought I might as well pick them up now - who knows what will come in years to come?
Also cheers on the heads up re silicon hoses - is the issue that they perish quickly or that they cannot handle heat? Any incites?
Yep - they do fail, and just as much of a pain to replace so good thing to do if the motor is out.
Also get the paint tidy'd up as well :geek:
Fair enough if you got a good price :D
I kept getting pin hole leaks which then results in coolant being sprayed all over the place.
From what i could tell the hoses are a bit thinner, and there isn't a lot of the webbing inbetween the silicone layers when you slice it open.
So obviously lacking support and durability/quality.
3rd time it happened it was the straw for me so went with OEM hose that was modded to suit.
Oh most definately the paint is going to get a tidy up :geek: one of the reasons of buying a full gaskit kit is I can paint all the parts properly. But as it is not a genuine reliability mod I didnt think to post it :D
Why are you pulling the engine out? How many km has it done? If you're going to take the sump off (and the head?) you may as well do rings and bearings. Replace and correctly torque the tensioner bolt when you do the cam belt etc.
Honestly, who knows how many Kms their car has done!? The engine is coming out for a few reasons. Firstly, as stated above I am doing my turbos and from the advice I have received from many people is it is just as quick to pull the engine and do them out of car. Secondly, I wanted to do the heater hoses and the vaccum lines for the engine - basically undoable with the engine in place. My gearbox is making some interesting noises which make me think the input bearing is a bit dodgey so I want to overhaul it as well. Its easy to service out of car.
Regarding doing the bearings and rings. Hmmm... The engine compression is good and it isnt using any oil. I am not planning on building a power monster so i cannot justify opening it up to that extent. Lastly and most importantly, the age old question - where do I stop? If I did the rings and bearings, I most likely couldnt justify the hassle of doing it without new throwing in some forged slugs. Then, if I am doing that should I hone the block, check the crank, have the head once overed, etc.... Basically not what I am aiming for atm.
Yeah the machining costs add up - which inevitably means you want to put the best parts in to make the most of it... luckily I'm not going down that route just yet :D
Ye the age old "where do you stop" is certainly real :whistling:
You'd be @ 4k before you began, then no point going those turbos... AFM changes, injectors and suddenly 10k+ has walked out the door!
Ripping the motor to do what you wanna do - is very ideal and smart.
Plenum & hoses are a pain in the ass and much easier outside the car as are turbos.
Overall cost would IMO, be cheaper labour wise as it doesnt take that long to get the motors in/out with experienced people.
Luckily my labour cost is $0 :whistling: Allows more parts to be bought. Ash - do you reckon the tomei sump baffle is worthwhile? I dont think I need to go to a larger winged sump, but as I might track it in the future the sump baffle is needed?
Honestly having seen cars running sticky rubber and a lot more power than you - they all did it stock sumps and 1litre overfilled.
So I'd say no. But it's your call but without doing the other head/oil mods etc, that's where the real problems are anyway
I have kinda been scared about putting an N1 pump on from the horror stories (i know many people have had success as well). I wasnt going to do an oil restrictor as I wasnt planning on cracking the engine open.
Does the N1 provide higher pressure / greater L/min?
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
