Check out Mearcat (he's on the forums): He makes some fantastic guage pods specifically for C34 Stageas: I use both pods: a single guage on the dash near the a-pillar, and a double guage pod that replaces the factory clock: they are very well made, and look great: very neat!
I'll post pics tomorrow...
hey guys after input on where to put sum gauges in my stag pictures would be good
I put in a single Din head unit and mounted three gauges in the space, also have my boost gauge in the A/C vent in dash on D/S.
I have my boost gauge on the dash next to the a pillar, hasn't caused me any problems yet. Only stuck there with a bit of double sided tape as well and there haven't been any holes drilled, so it's easy to change its location if I have to.
Can sort of see it in this pic
my gauges
Thats cool in the centre vent. Think I will do the 25G that way. Wont need a boost until son gets a full licence, by then we will have all the goodies required.
Yes please. I have my boost guage in the RH centre vent but don't really want to lose the whole vent. I would like oil pressure and temp as well and poss water temp (stock one is not very accurate).
I've only got a single-DIN stereo now, so I mounted Exhaust Temp, Oil Temp and Oil Pressure between the stereo and the HVAC controls (I managed to get an off-cut of 1cm thick thermo-plastic and cut the holes with a hole-saw), and Boost in a single Mearcat clock-replacement pod.
I installed an Innovative Motorsports wideband O2 sensor last week. Didn't want to drill holes in the dash and not sure how permanent it will be, so I ziptied it to the vent under the windscreen. Looks fine, doesn't get in the way and fairly stable. The clamp that comes with it is way too tall and chunky.
Hmmm JDMSprit's and Goldzilla's gauges look awesome :)
Sorry: Stag went to the workshop again, as I managed to collect my new daily: next week I'll have pics of the full Mearcat setup: They look great in the "flesh"- sit nicely, and require no holes to be drilled.
I was rather hesitant doing what I did. I had them double sided taped there for a while but the heat kept making the tape let go and I got rather annoyed so I took my time cutting the holes as flush as possible and Sikaflex'd them from the underside. As a plus it made the cups sit a good 4-5mm lower as the column cover is a good 2.5mm thick. I do plan on picking up a spare cover for what ever reason I feel like selling the car or removing the gauges in future. :)
  • 4 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
