hi all, just got a r34, and the left xenon light turns on then after about 15s turns off. it dosnt get as bright as the right side eather. why could this be?
could it just be the globe? and if it is, were do i get another one? any help apeciated! :geek: thanks
https://www.sau.com.au/forums/topic/336838-xenon-light-turns-on-then-turns-off/
You can get globes from any auto store, 2 for like $30. They're halogen though, even though it may have xenon written on them. Not sure what the problem is mate, my right one just doesn't turn on sometimes and I have to restart the car...
Edited by Galois
It may be the globe, it may be the bllast. Funny that it is the left hand side as I've seen a few R34's where water has got into the factory ballast that side and caused it to rust/short out. Best way to tell is swap the bulbs from left to right and see if the problem moves sides (bulbs issue) or if it stays on the left, ballast issue.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
