I'm putting my C210 on a dyno for a power run this sunday with the local cruising club in Perth "West Coast Cruisers".
I want to know the max rpm the car should be revved to, i've only ever gone to 6000-6250 when driving. Is that as far as i should take it?
Specs.
Stock internal L24, unopened only for headgasket in early 1980s).
Planed head (early 1980s).
Single, double barrell hitachi carburettor (standard).
Standard airfilter and air box/intake.
NGK BP6ES spark plugs @ 0.8mm.
2inch free flowing exhaust with extractors.
Standard Gearbox, worn synchros.
Standard diff, worn pinion bearings.
195/65R14 tyres, standard 14x5.5in rims.
Thanks
https://www.sau.com.au/forums/topic/336855-c210-dyno/
Man i was so close to dyno-ing mine last year. Keen to see what you get!
Mine has a very obvious power drop around the 5.5-6k mark. Well not a power drop, it just doesnt pull any harder. And the tappets start to sound loud around 6.5k rpm. So yea i wouldnt bother goin any more than that personally.
Post vid and dyno sheet for sure man. And have fun!
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5447211
Im not sure you will get a choice on what it gets reved to?, the guy using the dyno will usually take it to red line so you get a power curve print out, Im not saying this is the case every time but its always been like that when ive done them.
just make sure you have plenty of oil in it id say over fill it by half a liter and it will be just fine there a strong old engine.
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5447284
my car has "yellow" line from 6000 - 6500 then Red from 6000 - 8000.
I don't want the dyno dude doing an 8000, it's just too much for the car and with the stock radiator fan 4000+ sounds like an airoplane.
according to engine plate max power is made at 5600rpm anyway, so going 6500 i think would all it'd really need.
Thanks cam, does yours have aftermarket radiator fan?
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5447445
In my bog-stock L24e auto, I scored 53kW at the wheels, so it you top this with your exhaust and manual trans, let me know!!!
at for redline, I wrecked another R30 a few months ago, kept all the goodies. But before that i too wondered what the redline was... so I spent the next 40 minutes bouncing off 7000 rpm and doing HARD shifts, generally TRYING to break it. damn thing just kept going... I ended up running out of fuel.
Pulled it all apart over the next 6 months and the insides were fine, still had the factory honing marks in the cylinders, even had factory head gasket!
bloody tough buggers.
a few minutes on the dyno wont hurt it! just keep your tyre pressures up, and clean fresh air coming in the intake.
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5448083
i'll post up the dyno graph when i get it done.
i've got 35 psi in the above mentioned tyres, is that good?
i would suspect that the automatic was robbing power from the engine and that's good news about how high they can rev, it's just so loud from 4k +, one of the reasons I'm going twin thermo fans.
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5448191
It'll be fine, on a power run the dyno operator will only rev it till it starts dropping power and that will be way before it gets even close to 8000rpm probably closer to 5000-5500rpm on an L-block
Be warned if you've never had you car on a dyno before it can be worrysome watching it stand up for the first time :D
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5448412
Yea im running a thermo fan bro. The engine fan drove me nuts! It was louder than the exhaust ay.
Dont worry about tyre pressures too much. 35 should be fine seriously.
And when i put my silvia on the dyno, i had to tell the operator what rpm he did on the runs. That way he was not liable for blowing up the engine by over-revving.
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5449273
My old 200000km old L24E MR30 auto managed 62kW at the wheels, so expect something between 50-70 depending on how tired she is.
https://www.sau.com.au/forums/topic/336855-c210-dyno/#findComment-5451411
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
