Have a set of Weds Wheels I need to get rid of
Specs:
Weds Gradu
4x 17x9" +25 Offset All Round
Very Lightweight Mesh Style
Comes With All Centre Caps Etc
Have a little bit of scuffing on 1 wheel & could do with a respray hence why getting rid of them cheap
No Buckles & Balance up Perfect
$650 Quick Sale
Pick up or Freight to QLD Metro or VIC Metro areas for $80
Pics to come
Contact Via PM or 0419797023
Edited by krayzie32
Very solid built lighweight japanese wheels
im practically giving them away...
Spose 20" chinese chromies are the shizzzz these days...
Sorry $450 is bit low...
Ill take $530 cos your nearby it seems tho...
Still Pretty damn cheap for high quality solid Japanese wheels in good size with good offset...
lol no interest then all of a sudden i get 10 pms about these lol
Tyres are 255/40/R17 All around
and currently still fitted
Price is
$400pickup + shipping (no tyres)
$500pickup + shipping (with tyres)
^Hey mate shouldnt be a problem i think...
Could probably organise someone from work to same day deliver sydney wide for >$30 for those interested
depends what you want tho
id prefer to let em go with the tyres as its easier for me
but ive got about 10 people lining up for em now... First person with the cash gets em pretty simple
pm sent
And all pms regarding these have been replied to...
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
