hey,
sorry to make a thread but Question will get lost in the wasteland and want a clear answer.
now my old rb25 had oil blowby at the track (herd this is what rb's do at high revs) ok that fine.
bought rb26 rocker covers and mines cam baffles.
fitted these (removed pcv valve due to 26 covers not having them)
fitted plazmaman
plumbed my catch tank into the two breathers on the back of the covers with a kn filter on the tank.
now, as soon as these were fitted, i had oil vapour blowby coming from the catch tank setup.
any ideas on what to do?
https://www.sau.com.au/forums/topic/336902-question-of-help/
nah just ripped the old motor out..
new one will be tuned tomorrow..
but wanted to know if not having the pcv valve is what caused the so called blowby?
The PVC valve allows pressure out, not in ... so I don't believe that is contributing to your problem. I would take a compression test. If compression is leaking past your piston rings, that'd be the contributor.
Hard to diagnose over the internet in any case. :D
hey,
fitted plazmaman
Actually, when you say you removed (didn't use) the PVC valve, did you still have the hose from the plenum to the rocker covers (just without the PVC valve). If you did, then thats your problem. On vacuum your sucking oil vapours into the plenum ... and on boost you'd be boosting air into the engine, pushing the oil out any exit, ie the catch can.
:D
nah, plazmaman and rb26 rocker covers dont have any nipples/ports to have a pcv valve..
so i was running in theory a "blocked off" system.
on a rb26 the pcv valve runs from the drivers side rocker cover breather to a nipple on a metal bar next to fuel rail.
Jolly good then old chap! :D
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
