hey all, i bought this setup not long ago to put in my 180 but unfortunatly things have changed for me and if i can make most of what it cost me back ill be selling it up.
basic rundown.
RB26DET
sard 600cc injectors
tomei poncams
modded sump for rwd
unknown bottom end. can only be presumed standard.
Heavy duty clutch
loom etc.
$3800
T78 33d kit.
trust mani
hks 50mm gate
dump pipe
turbo looks to be in really good condition other than some slight marks on the comp wheel (run with no filter)
$2900
Power fc
Greddy twin intake
Z32 AFMs
fc commander
$1400
trust oil cooler kit.
sandwich plate etc all lines included with earls fittings
$800
i have other little things like stock ecu, a/c compressor etc.
nothing will be seperated until ive sold the motor/turbo kit.
cost for all of the above complete is $7600 firm.
Edited by boostd gem
interested in the turbo kit.
what power did u make with this setup at what rpm. do u have a dyno graph?
what is a t78 rated at horsepower wise?
thanks
julz
for anyone interested, this wasnt run without a air filter, so no worries there, it's just one of the air filter's was damaged so i didnt worry giving it to him. they were run with blitz twin pods so there is no issue there. I'm also pretty sure this engine runs oil restricters due to the oil pressure readings it was getting (always really good).
this engine is built for huge power, if that's what u want, then u cant go past this package.
Is this your old engine nisskid?
yeh mate, really strong engine, and the T78 was amazing, i didnt wanna get rid of it, but had to let it go as i was in too much debt because of it haha
i just wanna see someone get this and give it a proper tune, see what it can do, i lost the tune not long after i bought the car and was too retarded to work the boost controller, so it ran on a base map and 12psi for most of the time i had it.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
