HEY GUYS,
I have a set of 6 Blitz 525cc Injectors for sale.
Injectors have only done 2,000kms and are in very good condition, pretty much brand new.
Also have a Z32 Air Flow Meter that i need gone as well. Also in very good condition
$750 - Blitz Injectors
$250 - Z32 Air Flow Meter
Can do $900 for both.
Shipping at buyers expense.
Im from Melbourne, Victoria..
Pick up is also available
PICTURES WILL BE UP SHORTLY GUYS,
Thanks =)
Edited by p.dellaglio
Any pictures of the injectors? Are they a direct fit? Would they require spacers for the fuel rail? Have they been checked?
Hey man,
They fit in perfectly although they are a bit long so the spacers come with them for under the fuel rain.
Ill put some picks up hopefully tmoz.
They work 100%
Ill get picks up tmoz.
cheers
Anyone want to make an offer?
Sorry i havent put piks up yet, been so busy with work etc.
Will try to by the end of this weekend.
How much rwkw's can these injectors handle?
Well even though the standard AFM in the 34's are solid, your better off bundling the Z32 with it as well. Both together will get you 300rwks SAFE.
cheers
Are the spacers the only modification required to fit, or do you need different plugs?
Hey mate,
Nope, no other mods needed... the spaces fit under the fuel rail and thats it!
Nothing else needed man :)
hey mate just confirming that these will fit the rb25det NEO motor? and what sort of power/boost would they max out with a gt3076? sorry pretty new to the scene. please pm me with the lowest you will take for injectors and afm. and a rough postage price for sydney. sorry post count too low to pm you. thanks
Hey man,
With both the afm and the injectors, and then if you get yourself a tune as well, you can EASILY push 300rwks safe.
The standard afm in the rb25's can take 200-210rwks. (im kinda new on the scene as well, thats what i was told by someone with a bit of experience)
Ill PM you a price, but its $20 for the postage to Sydney,
Cheers,
Patrick
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
