Hey all - am chasing the names of companies that can rebuild my turbo. The only one I know of is Turbotech. Any others that you would recommend or have experience with? PM me if you feel your comments aren't appropriate for the forum. :thumbsup:
Thanks...
https://www.sau.com.au/forums/topic/33696-turbo-rebuilders-in-perth/
  • Replies 48
MIQ which is in Victoria road Malaga.9209 1677
Used to be the old Dynamic Turbos operation and is now run by a guy called Eric.
Knows his stuff but can be depressing to talk to :thumbsup:
If you have spoken to him you'll know what I mean. Did my 581's and rebuilds most of Maximums Subaru rally ones.
cheers
Ken
Cam,
Any truck or boat tech shop will be able to do it. I had the problem with the old Supra before anyone knew about Jap Imports, just find one of those places, if it is just seals, or trhe mill or the bearing, they will build it and replace component and preasuree test it and all..................
TurboTech charge arm and a leg.........................
They think they are the only gusy in the City, ehehehhehe, but in fact lot more people know the turbo components........
al
The good thing about those places they can find parts for them without you having to buy entire kit for the turbo...............
Any diesel engine shop, might be able to help......if you are finding parts as stand alone or got the turbo out and can do it yourself.........
My sisters huby did it for me :(
Thanks for the info guys.. I ended up saving my pennies for now and sourcing a 2nd hand stock unit.. The upgrade will be comming after my Euro trip this year (which is why I'm trying to save $)...
Again - thanks guys.. I think I'll be getting a VL unit in October. :(
Hmm - fitting the turbo is turning into more than just a re-bolt on. Have found some problems as a direct result of bad workmanship by *** performance (in wangara - you work it out) who fitted the dump - missing bolts and flange holes not lining up by a mile. You wouldn't think the fabrication of a flange would be so hard...
Anyways - on inspecting the compressor wheel on my old turbo vs my new one, I found that the new one has dual vanes while the old one has single? Any ideas? I'll post up comparative pics tonight.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
