Cam, I think it's possible to put a steel wheeled RX7 turbine in a machined RB25 turbo housing, might cost the same as a rebuild but provide a bit more power and reliability.
Im quite sure this is what I have, boosts up to 16psi easily, one day ill get around to the dyno.
  • Replies 48
I always use ATS in O'Connor
Cheap n Freindly service.
Rebuilt my VLT T3 with T4 internals as well as Hi Flowing......$1200
It has produced about 280rwHP @ 9psi on 9.0:1 comp RB30......I'm hoping it will be good enough to produce 400rwHp on 7.8:1 Bottom end I now have !....?
Anyways - on inspecting the compressor wheel on my old turbo vs my new one, I found that the new one has dual vanes while the old one has single? Any ideas? I'll post up comparative pics tonight.
Righto - Pic of the old vs new compressor wheels attached.. Any ideas?
Hmm - fitting the turbo is turning into more than just a re-bolt on. Have found some problems as a direct result of bad workmanship by *** performance (in wangara - you work it out) who fitted the dump - missing bolts and flange holes not lining up by a mile. You wouldn't think the fabrication of a flange would be so hard...
Pic attached of the poor workmanship of the dump. Absolutely pathetic and I think people should know so they can be aware of the quality of work to expect out of some places. You could argue that it'll work - which it will - but you'd expect this sort of crappy workmanship out of a backyard mob - not from somewhere who suposedly specialises in "performance" work.
i know with the mitsi turbos the TD04 is single blade and the TD05 has the twn blade thingo like yours cam, not saying its mitsi, but maybe some sort of upgrade, which might explain rev's times??
Might explain my times if this turbo was actually off my car. My turbo has twin blades tho' for the record.
I personally think people underestimate the effectiveness of a lightened flywheel..
*thinks back to the nissan micra super turbo on GT2 and the difference it made when he lightened the fly*
granted, that was a puter sim, but a lightened fly would make a hell of a difference.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
