I've got 20x8.5 Verde kaos black Wheels and tyres
5x114.3 stud pattern ,offset +38
Few marks on the rims
Tyres are 225/30/20
2 of them about 75% tread left and 2 of them camber wear about 60% left
$900
https://www.sau.com.au/forums/topic/336960-20-verde-wheels-tyres-cheapp/
Tyres are 225/30/20
$900
Hi! are your rims still available? if so please contact me 0404 570 069. Cheers
