Hey guys, i've got a bunch of parts left over from wrecking a R33 gts-t:
PM me if you're keen on anything
Can post everything unless otherwise specified
RB25 Engine stuff:
S2 AFM (pick sticker) + plug - $100
S2 coil packs x6 - $120
rb25det injectors x6 - $120
CAS - $80
AAC valve - $50
Harmonic balancer - $100
bare rb25 intake manifold - $50
standard exhaust manifold - $50
throttle body + S2 TPS - $50
rb25 bare head, had approx 108,000k's, great condition - $500
complete S2 engine wiring loom - $150
engine mounts - $75
post-35556-1284549639_thumb.jpg post-35556-1284549604_thumb.jpg post-35556-1284549660_thumb.jpg post-35556-1284549682_thumb.jpg
post-35556-1284549755_thumb.jpg post-35556-1284549935_thumb.jpg post-35556-1284549951_thumb.jpg post-35556-1284549962_thumb.jpg
Other engine stuff:
HKS SSQV bov - $170
FMIC kit for R33 - Takashi (?) intercooler, includes all piping, hose clamps etc - $250 pickup only
Monza catch can with lines - $70
Turbosmart boost Tee - $40 posted
post-35556-1284550003_thumb.jpg post-35556-1284550023_thumb.jpg post-35556-1284550075_thumb.jpg post-35556-1284550051_thumb.jpg post-35556-1284550184_thumb.jpg
A/C compressor - $100
S2 A/C condenser - $150
R33 radiator - $100
post-35556-1284550238_thumb.jpg post-35556-1284550256_thumb.jpg post-35556-1284550291_thumb.jpg
3" dump/front pipe, kinda fugly but gets the job done - $70
3" cat converter - $80
3" catback exhaust, mid muffler is a bit dented but should get the job done - $200
post-35556-1284550303_thumb.jpg post-35556-1284550315_thumb.jpg post-35556-1284550346_thumb.jpg
Under car stuff:
Cusco height adjustable coilovers, comp-S i believe, awesome condition - $950 ono
driver side front lower control arm - $50
steering rack - $100
castor rods with urethane bushes - $80/pair
Front hubs- $100/pair
Rear hubs - $150/pair
front rotors, recently machined - $50/pair
rear rotors, recently machined - $50/pair
rear calipers - $150
R33 manual tailshaft (complete) - $100
rear driveshafts - $75
4.11 (manual) ABS diff - $250
post-35556-1284550537_thumb.jpg post-35556-1284550526_thumb.jpg post-35556-1284550508_thumb.jpg post-35556-1284550850_thumb.jpg
Interior stuff:
Floor mats, full set - $100
5sp manual gearknob, awesome condition - $50 posted
Razo Re40 turbo timer & wiring loom. I scabbed a picture from the net that shows it lit up - $80
S2 airbag steering wheel, awesome condition - $250
S2 door trims, front and back - $100 pickup only
rear parcel shelf - $50 pickup only
post-35556-1284550571_thumb.jpg post-35556-1284550585_thumb.jpg post-35556-1284550606_thumb.jpg post-35556-1284550621_thumb.jpg post-35556-1284550646_thumb.jpg post-35556-1284550675_thumb.jpg
https://www.sau.com.au/forums/topic/336968-r33-skyline-rb25det-parts-sydney/
Very interested in the coilovers pm me with your best price as I'm in Canberra I'd be looking at driving up to get them.
Cheer Jason
PM Sent, sorry, didnt realise FMIC was sold when sending it!!
No probs, PM replied
Hey dude, can't shoot you a pm lol, new member fail.
Drop us a msg at 0466 823 073
Hey, what were you after? few bits are sold / on hold
Cheer Jason
Heya, coilovers are on hold till friday. will let you know asap if it doesn't happen
Cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
