I have tried 1mm and 1.5mm, also using an N1 oil pump, both cases left me with a noisy head, on idle. Now i am ripping the restrictions out and running the std 2mm. Hopefully that would make it sound normal again.
Just my experience
PS: Any revs above 1000rpm, and the head sounded perfect/normal. Pulled down the head and found no wear on lifters or cams; after 10,000km.
https://www.sau.com.au/forums/topic/336972-oil-restrictors/#findComment-5449211
Just my experience
according to a build guide i have rb30s have 2x1.8mm restrictors as standard and rb25s have 2x1.5 standard but it recomends to use 2x1mm?
Moogley you've seen the man's advice. It's a fairly common experience - the issue is obtaining sufficient flow from the pump at low revs (idle) through a small orifice to fill the hydraulic lifters.
I have a stock pump with 2mm shim, and 2x 1.6mm feeds and no VCT. Hot or cold start it takes ~ 2-3 secs to pump up the lifters and otherwise the top end is silent at any engine speed. I expect it and can live with it
The other thing I found was a big impact by the grade of oil used on cold start oil pressure and lifter noise. The guide is just that, not a Bible. If you're 100% road use then stick with the stock feeds to avoid noisy lifters. But do drill out the internal oil returns in the block and head.
https://www.sau.com.au/forums/topic/336972-oil-restrictors/#findComment-5453867
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
