Im after a second opinion I think ive put the cambelt out by a tooth or something. Motor turns ova like a dream. fired upp once but run like a dog for about 3 seconds . Everytime after i stop turning it ova it does a really sad sounding backfire .
sweet . if its a tooth out do you rekon there will be any damage ?
No it won't damage it.
Neither will is stop it from running, make sure your not 180 out on the crank if you have recently replaced the belt or something.
Sounds more like a spark problem to me but.
Edited by James_03
Sweet as yea checked number 1 piston and its up the top when its top dead center. Good to hear there shouldnt be any damage. It lowkey fired up once but run like a dog. I checked the belt and the right camshaft was like 2 out i think . If the cambelt tensioner that you move is a couple mm out would that effect it. Motor was running before hand Ive just changed the blocks because the rings went in the old one . Everything seems to be sparking finie. checked all the wiring to make sure i didnt miss anything.
what if its opening a vlave when the piston is all the way up.
probly snap or bend a valve. Its still turns over sweet no odd noises inside yet
Put a ratchet on the front balancer bolt and turn it over with your hand to make sure it doesn't hit any valves. I accidentally put my timing belt on 180 degrees out once and the pistons bent some valves, it didn't hit that much but it was enough to tweak the valves so they didn't seal properly.
yea still turns over sweet with a rachet the number 1 piston is at the top when all 3 marks are aline is that right? . You rekon give it a compression test to see if if ne arnt sealing. lol myt b over before i get to go for a roll
sounds like what happened in my fathers RB30 EH Holden..
Ended up being the coils firing in the wrong order...
Do the Basics.. check u have fuel.. If u have disconnected them, check u have the feed and return around the right way.. (i hooked them up the wrong way.. it was a pain)
check spark... and your timing is all good by the sounds..
check that the crank angle sensor still has the key way in it and is lined up correctly, also when u pull it out to check it make sure the CAS shaft isnt broken, my old gtr did this too me when i rebuilt it, it happened because i didnt use the perfect sized spacers when running it without the top timing cover
yea algud ended up getting it going. there was a pin in one of the injectors broken and weak spark. But sussed it all . Started off on 5 pound then I raised it to 12 psi and it lasted all of 5 minutes . blew the head gasket it was only a cheap job of trademe. Going for a gtr 1 this time. Spend the money get the results youre expecting lol
Does it have a base map to run it? If not I'm not surprised it doesn't start, probably massively overfueling?
Nah no bass map just a 260kw tune on 14 psi . got it going in the end but just blew the head gasket for some reason. Was only cheap hundy dola 1 of trademe. Going for a genuine gtr one this time.
check the timing with a timing light, also check all 6 spark plugs to make sure they are all firing and not wet with fuel..
Jarrod
yea did that they had a pretty weak spark which i eliminated just was using a real shit earth. got it going for about 5 min then blew the head gasket some how . think it was just cuase it a cheapy . gona use a gtr one this time.
If all the marks are lined up then you're valve timing is fine.
yea m8 it was lol i was starting to wonder if i was cross eyed but it was bang on
Tuned on a dyno or was it an existing tune?
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
