Im after a second opinion I think ive put the cambelt out by a tooth or something. Motor turns ova like a dream. fired upp once but run like a dog for about 3 seconds . Everytime after i stop turning it ova it does a really sad sounding backfire .
sweet . if its a tooth out do you rekon there will be any damage ?
No it won't damage it.
Neither will is stop it from running, make sure your not 180 out on the crank if you have recently replaced the belt or something.
Sounds more like a spark problem to me but.
Edited by James_03
Sweet as yea checked number 1 piston and its up the top when its top dead center. Good to hear there shouldnt be any damage. It lowkey fired up once but run like a dog. I checked the belt and the right camshaft was like 2 out i think . If the cambelt tensioner that you move is a couple mm out would that effect it. Motor was running before hand Ive just changed the blocks because the rings went in the old one . Everything seems to be sparking finie. checked all the wiring to make sure i didnt miss anything.
what if its opening a vlave when the piston is all the way up.
probly snap or bend a valve. Its still turns over sweet no odd noises inside yet
Put a ratchet on the front balancer bolt and turn it over with your hand to make sure it doesn't hit any valves. I accidentally put my timing belt on 180 degrees out once and the pistons bent some valves, it didn't hit that much but it was enough to tweak the valves so they didn't seal properly.
yea still turns over sweet with a rachet the number 1 piston is at the top when all 3 marks are aline is that right? . You rekon give it a compression test to see if if ne arnt sealing. lol myt b over before i get to go for a roll
sounds like what happened in my fathers RB30 EH Holden..
Ended up being the coils firing in the wrong order...
Do the Basics.. check u have fuel.. If u have disconnected them, check u have the feed and return around the right way.. (i hooked them up the wrong way.. it was a pain)
check spark... and your timing is all good by the sounds..
check that the crank angle sensor still has the key way in it and is lined up correctly, also when u pull it out to check it make sure the CAS shaft isnt broken, my old gtr did this too me when i rebuilt it, it happened because i didnt use the perfect sized spacers when running it without the top timing cover
yea algud ended up getting it going. there was a pin in one of the injectors broken and weak spark. But sussed it all . Started off on 5 pound then I raised it to 12 psi and it lasted all of 5 minutes . blew the head gasket it was only a cheap job of trademe. Going for a gtr 1 this time. Spend the money get the results youre expecting lol
Does it have a base map to run it? If not I'm not surprised it doesn't start, probably massively overfueling?
Nah no bass map just a 260kw tune on 14 psi . got it going in the end but just blew the head gasket for some reason. Was only cheap hundy dola 1 of trademe. Going for a genuine gtr one this time.
check the timing with a timing light, also check all 6 spark plugs to make sure they are all firing and not wet with fuel..
Jarrod
yea did that they had a pretty weak spark which i eliminated just was using a real shit earth. got it going for about 5 min then blew the head gasket some how . think it was just cuase it a cheapy . gona use a gtr one this time.
If all the marks are lined up then you're valve timing is fine.
yea m8 it was lol i was starting to wonder if i was cross eyed but it was bang on
Tuned on a dyno or was it an existing tune?
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
