Gday im just about to get my licence and i need sum help.
I have been thinking of getting a r33 gtst but i keep getting told all different opinions on weather i can drive it on my p's or not (power to weight ratio). But im also looking at getting an NA r33 which is pretty stock cept for an exhaust and wheels and few other standard bits and pieces. But im being told they r fairly sluggish in standard form so im wondering wot i can do to it to give it a bit of go, if i choose to get a NA because i cant get the turbo.
Also im told insurance is realtively the same for both cars..........?
Im confused ne help apreciated.
https://www.sau.com.au/forums/topic/33701-need-ur-opinion/
as I understand it, on your P's your only allowed 125kw per tonne or 3.5litres per tonne.
the r33 skyline is "actually" 138kw per tonne (car weighs round 1300kg)which means you cant legally drive it........BUT......VicRoads class the skyline as a coupe and automatically stamps it on the rego sticker as a 1500kg vehicle......which makes the skyline 120kw per tonne...which means it's legal.
so it's a bit of a grey area really. I drove round on my P's in a 5lt V8 commodore, when ever I was pulled up I told the cops it was a 253 (4.2lt) which they couldnt prove otherwise short of pulling the motor out so it was all good. Plus they wouldnt have a clue anyway. Dont do stupid things and you wont be hassled (well dont do them in built up areas anyway), steer clear of cruising round late at night/in the AM hours of the weekend.
Heaps of R33's round Geelong are P platers so I'm guessing its legal. VicRoads fault...."i didnt know the weight of the car......the sticker says.."
hope I've helped
https://www.sau.com.au/forums/topic/33701-need-ur-opinion/#findComment-675928
yeah theres a thread in the N/A section covering insurance for an N/A vs turbo, its not that much difference, like $500 tops depending on other conditions and your history age location etc...
abcent has a good point, not sure how that would hold up, does that apply to all r33s?
does this mean
u: the car is 1500kgs, look at the sticker
authorities: oh its wrong here lets weigh your car, oh look it weighs 1300, here have a fine
or cos vicroads stamped it wrong means they cant do shit?
interesting technicality
https://www.sau.com.au/forums/topic/33701-need-ur-opinion/#findComment-676152
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
