r33 stock injectors x2 sets $90
r33 s1 stock coil packs $50
r33 s2 front foggers and indicates $60
r33 stock wheels 16: 2x %70 tred 2 x %5 $180
r33 stock dump and front $40
r33 aftermarket split dump and front been cut for screamer stock fitment bolt on holds boost like no other dump pipe ONLY BEEN USED ONCE(plus adds a good screamer sound) $ 180
r33 centre console $40
r33 stock turbo never been boosted over 9 psi $290
r33 turbo t43 good for making 240rwkw minimel shaft plat comes with dump pipe to suit $350
r33 cat mangaflow high flow cat almost brand new $90
r33 s2 rear spoiler $70
r33 ecu's 2x s2 Manuel 1x s2 auto ( all turbo models )$50 EACH
r33 stock boost controller $35
located in melb can send some of the items
0430106414 call me for any questions and ill do all i can to help
https://www.sau.com.au/forums/topic/337029-r33-parts/
does the t43 turbo bolt straight on to ser 2 gtst
yes it does its staight bolt in you can look up the rest of the specs from hyper gear if you like or feel free to call me on 0430106414
and i will try to help with anything i can
Regards
Abe
https://www.sau.com.au/forums/topic/337029-r33-parts/#findComment-5451827
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
