I've been made aware's that a few of you might be after some dumps again.
If we can get about 10 partys interested i'll get him to make some more up
we'll do them in mild steel this time with ceramic coating. the stainless was painful to work with dew to the rather strange bellmouth size and design.
This is a photo of the similar design, its a stock replacing dump, so can work with your stock exhaust without problems.
Sorry i dont have a photo of the last ones we got made.. i am sure someone will post one up
should be ballpark of $400
https://www.sau.com.au/forums/topic/337039-m35-dump-pipes-again/
  • Replies 270
how about delivery to the UK ?
I can tell you that if I had my time again and limited budget for an exhaust upgrade I would only do the dump pipe. It created the biggest difference to mid range power.
I took some photo's of my stock dump to give you all an idea about the limitations of it. You will see in the second shot the Cat that is inside the dump and this is a huge restriction and for any one running a stock turbo also a big risk as it retains so much heat that it leads to premature turbo failure.
Can anyone tell me if changing the dump pipe is a DIY job?
Would most people tackle this themselves or take it to their favourite exhaust shop for fitting?
In any case, I'm thinking seriously about it.
I was told by others in the know you can.. but its not easy without a hoist and some deep 1/4inch sockets of size 14.
i got mine done at a reputable exhaust shop for $280. but it wasnt just the dump..full system inclusive of dump for the install cost.
I did mine my self and with the help of a mate we did it in about 3 hours but this was on a hoist and a good selection of sockets and extensions.
The hardest part is getting the stock one off the turbo as it wil have been there a few years untouched getting hot and cold but mostly hot.
You also need to remove the mounting bracket from the stock dump to fit the new dump pipe.
If you can get your car off the ground and are handy with tools, you should be able to do it.
Hey guys i will wait a little untill we can get close to 10.. and then get stuck into them when i have the time... which i have plenty of at the moment.
i've twisted my mateys arm and hes keen to get involved again also..
Sound's like I could get just the dump installed for a couple of hundred $ at most.
I'm relatively handy on the tools but my selection has grown a lot smaller over the years (lost/borrowed & not returned) but I don't have ready access to a hoist.
Thanks for the feedback guys.
I'll keep an eye on this thread for the time to buy.
Can anyone tell me if changing the dump pipe adds very much to exhaust noise?
I've got to sell this mod to my wife (it's her car after all), so it's got to be all about the fuel economy and long turbo life. Power gains are only secondary (for her) but a big increase in exhaust noise will leave me in the dog house for a loooong time.
It only adds a little to the in cabin noise. I did the exhaust first so not a perfect comparison.
Mine is made of stainless steel so when I do work on the turbo next I will wrap my dump pipe as the floor under my wifes feet get a little warmer without the exhaust shield.
If these new one are ceramic coated you won't need this.
Cheers
Andy
I fitted the dump pipe alone before doing the rest of my exhaust. I used the "this will make life easier for the turbo, extending it's life, AND we'll get better fuel economy cos there's less restriction" route to justify the purchase, and thus far both have been successful :blink: . Definitely the best single mod, and it only improves as you move further through the exhaust upgrades. 'Course if my turbo fails I'll have some questions to answer...
The added noise issue is a bit of a non event, You can hear the whistle a little more, slightly metallic sound, not unpleasant. The other side of that is, I'm convinced the turbo spools up faster, so the engine noise doesn't mask it as much. All up though, you won't really notice much change in noise; only performance :D . Mine's heat wrapped, so no heatsoak issues to speak of, and this may also damp a little bit of noise.
I'll take one.
Mine is at 99,500km, so I'll probably have a good opportunity to change it when the turbo goes... Already have a custom cat-back.
As I have never had a turbo before can someone indicate on a stock 2002 M35 an average life with an average driver?
Currently done 112,000k.
If only the dump pipe is bigger but the other pipes remain the same size, eg no muffler change ,wont the gases exiting still exit at the same rate . I don't think anything will change in terms of gases leaving quicker.
Just trying to understand the physics of a better performance.
When they say fuel economy or power is better are we only talking 2 or 3 percent ,5 or 10 percent or what? . Can i get a ball park figure?
Anyway I am also seriously interested based on the positive comments of others.
Edited by samuri
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
