My brother's mate's cousin said he saw a stagea like ours with a full exhaust and it had less power. I'd rather take his story than believe people who own the cars and have actually done the work :D
  • Replies 270
  Angus Smart said:
Hey mate,
yeah there is atleast ten,
i'll get get my shit together and go get the flanges made, and get my matey into gear.
Cheers mate. I really appreciate it.
  zei20l said:
My brother's mate's cousin said he saw a stagea like ours with a full exhaust and it had less power. I'd rather take his story than believe people who own the cars and have actually done the work :P
Hah! That's GOLD. Why is it that everyone believes the crap they "hear at the pub" over, well, the TRUTH!
For me I am getting it purely to lengthen the life of my turbo.. Don't care bout economy/power increase.. I'm much more worried boutthe cost when the turbo blows.. Which will come just hopefully not too soon!!! I say for $400 odd dollars it's a good investment over that under-engineered piece of crap Nissan call a dump pipe!!
for me it was such a discernable difference that when i drove away from the exhaust shop.. i could feel it on the first hill exiting the driveway.. gets on boost alot earlier and the torque was heaps better off boost also. what amazed me was the fuel difference.. someone said its not going to get 6l per 100.. well its pretty damn close.. its going to get 8-9 with the dump and cooler mod ive found...(against 12+ without) again depending on how you drive at the time. but i noticed a huge improvement on fuel economy. (almost a quarter of a tank difference over a week just crusing up the hwy).
Edited by PetroDola
is the economy due to the fact your turbo is laggier and youre not on boost as much as you would have been therefore not using as much fuel?
i found that with my SR20s with larger turbos. The car drove quite well off boost due to being in traffic/cruising mostly. on boost was another matter :P
  iamhe77 said:
Andy and Dale are right on the money
Couldn't agree more.
I think I will....... go........ with those who........ know.And that's why I joined this forum
How many hours ( approx)to do this by an exhaust shop ( I presume would be the best option) as I cant do this.
I think mine charged me for 3.5 hrs.
lol!!!!!!!!
As a person who has probably done everything other than an E85 conversion to get the most out of turbo that choses not to work with the car but should work with the car and probably would with any other car!!!!.....but this car is "NOT THE SAME AS MOST CARS" so it doesn't....yet!
Order of noticeable improvements
1. THE F$#KING DUMP!!!!!!!
2. A good air filter
3. The Exhaust
4. FMIC
5. Turbo
6. ECU upgrade or piggyback + Injectors +runner spacer + Fuel pump + suction pipe(good luck with this one as there are only a couple of people that can do the ECU properly)
Order of improvements for the summer weather
2. FMIC
3. Phenolic runner spacer
4. Nismo thermostat
Sorry if I have offended people but.........oh f#$k it! If you don't believe us do your own thing!.....maybe shoot Gale Banks an email and ask him about the VQ25DET!
Edited by Jetwreck
Will start collecting when they are almost complete. probably when we send them off to get ceramic coated.
I'm just waiting on my mate to get some time so we can get started. i'll go sort out the flanges to get laser cut soon.
They will charge you through the arse for it, but they shouldn't.
It is tricky, but if a couple of non-professionals can take the dump off in about 2-2.5hrs without a hoist, I am sure a pro could get it done in under 2hrs.
(and no, it is definitely NOT an engine out deal - I think I forgot to answer that q in your pm, sorry)
  Daleo said:
Well said Craig, f##ks me why people want to keep re-inventing the wheel...
Why believe anyone who's done EXACTLY what you're gonna do? What would they know anyway?
Dale, you definitely do NOT want to do exactly what Craig has done, mate.
yup i can confirm the dump install is a bitch of a job. but with the right tools and getting the car high enough youll be fine.
just gotta drop the rear of the transmission down to get access to the top bolt of the dump. long extension, uni joint and plenty of torque will do it no problems at all!
You make it sound so easy when you put it like that :)
Not sure if I put my hand up in this thread yet or not, but I need to get rid of my pesky dump-cat too :) I'll probs attempt to install it with a mate using a hoist, key word perhaps being 'attempt' :)
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
