  • Replies 270
Well said Craig, f##ks me why people want to keep re-inventing the wheel...
Why believe anyone who's done EXACTLY what you're gonna do? What would they know anyway?
didnt someone re invent the wheel?
to make it BALL BEARING! Thats what i did :) :)
to make it BALL BEARING! Thats what i did :D:)
Just seems to be a contingent that keep going "blah blah from such and such, says blah, so why would a dump pipe do anything?"
There's a crapload of evidence that says a dump pipe is seven shades of awesome; so why argue, just benefit from the research & investment of others. Never once seen a dump pipe on a factory car that couldn't be improved on.
sure thing!! at the rate we're going now i am going to make more than enough.. i am not sure we will do this again, so i will have some spares for a few latecomers, i've also noticed in the last 5 months a bit influx of volvo owners so we'll try cater for them too.
picking up flange today.. so we're getting closer to starting!
ive got my dump sitting in the boot, Scott NM35 made me one.. just waiting for it to be fitted. hope i notice a difference.
If it is anything like the beastly unit he made for me or the even larger (!!!!) dump pipe he put on his own M35, you will certainly notice quite a difference :P
Edited by iamhe77
He said its bigger its virtually a 3.5" from the mouth of the weird looking flange, to 3" connecting to the rest of the exhaust..
what do you think I should notice?
1. Definitely the response from the turbo. With little to no restriction on the exhaust side, it will come on boost harder and earlier.
2. More power throughout the rev range as well although it will be more noticeable in the low and mid revs.
Only down side (if you can call it that) is that you may have a little trouble with your turbo getting enough air from the intake... I know I did.
Maybe hit him up for a suction pipe as well while you are there on Saturday.
Edited by iamhe77
I'm pretty sure thats about the same size we've used before.
So, another week has passed. How is everything progressing? I know everyone's busy and it's only going to get busier as we get closer to Christmas.
Do you think an ETA of late this month is acheivable? (Can you tell I'm keen to get mine...? :) )
Cheers
haha yes can tell your very keen, i am off work at the moment and i'm getting everything i can organized to get it started..
however my friend who will be doing all the fab is very busy when hes not working his 9-5.. after work hes usually found working away on his new set of monkey bars..
I'll keep pestering him tho! and try aim for end of this month or early December
Cheers Angus. I'll leave you with it for a while and keep an eye on this thread, or check in with you again in a few weeks.
BTW, that looks like an interesting project you've got going on in the pic.
No sweat,
yer thats the guy's car who will be doing the welding for the dumps.
the car hes doing there is insane! cant wait for it to be out on track. k24a with twinscroll gt35 in a sprinter.. well whats left of a sprinter anyway. full Irs suspension and moar.
haha how wierd.. wht510.. i am in the same boat. ive put a deposit down on a m35 thats still in customs.. though i already want one of these dump pipes..
and wierder still i got a Datsun 1600 SR20 too! ;)
btw is it approx $400 delivered?
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
