hey guys got these parts left from my shell need them gone asap!
ONLY got these parts left, don't even bother asking if i got something else I'll just simply ignore you glare.gif
located in Mulgrave 3170 (Vic), willing to post the smaller stuff.
- stock turbo(missing actuator) & dump pipe: $140
- stock front pipe: $50
- throttle body sensor [tps]: $50
- pipe that goes from turbo to afm: $30
- bov return pipe: $50
- turbo heat shield: $40
- injector resistor: $40
- drive/fan etc. belts all 3(brand new): $50
- power steering reservoir: $30
- battery: $60
- wiper/washer bottle: $40
- AC fan: $60
- 1 stock coil pack: $30
- oil dipstick: $15
- airvent that goes from airbox to front of bonnet: $30
- driver seat: $90
- passenger kick panel: $25
- under dash trim panel: $25
- dash cluster surround: $30
- demister switch: $20
- hazards/tune switch: $20
- AC Unit: $70
- AC/ heater blower motor: $80
- brand new front rotors(gone orange from sitting outside): $90
- orange passenger indicator(slight crack and scratch, still works): $40
can provide pictures if needed..
thanks.
Edited by wAAA`
https://www.sau.com.au/forums/topic/337077-r32-gtst-parts-melbourne/
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
