  Madaz said:
that's fine for others to do but i wont ask others to lie on paperwork saying I'm only receiving so many $$$ of parts and trick the government out of tax
pretty sure they would send in separate parcels to keep it all above board
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5454974
  • Replies 92
Posted Images
you wouldn't have to change rails again Mark
and for injectors it depends on how much headroom your current ones have in the tune you currently have
Pete quite possibly, but someone else can organise it i got to much to do already thinks of @ least 2 events that need organising
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455089
  jenkies said:
feelings ey.... well im upset with life because..... oh feelings about e85. im sitting on the fence till it becomes more common.. not really down with changing rail and injectors just yet, already done it once :cool:
if its for the gtr then the top feed 1000's are around $600 delivered. and they use the std fuel rail. 1600's I think require the bigger fuel rail - you'd have to ask LukeENR34 if his 1600's fit into the stock rail - and theyre around $850 or something delivered
** depending on exchange rates, cc capacity, types of injector and impedance
-D
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455459
-D
dohmar can you get 1000cc side feed injectors for standard rb 25 rail?
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455480
  Dohmar said:
no idea sorry - best to ask willall or any other tuner/member who actually runs e85 - i just run 98ron
-D
no worries will do, going to move to e85 eventually, probably purchase some injectors from you at some time in the future. Still in research stage at the moment.
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455566
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
