Thats the wiring diagram that i found but it doesnt contain any settings or wiring for stagea.. it hasnt even got r34... it only goes up to r33
You will find the settings for the Laurel C34 and Skyline R33 are the same - use those as Chook says. When you have done that you should set all the knobs to zero until you can get a wideband meter or preferably have it tuned on a dyno by someone who has. For best results you should now try to track down an Apexi SITC to adjust the timing. But a Greddy E-manage would be better.
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5451685
Try reversing the toggles - it can be hard to tell whether they are supposed to be up or down. 1,2, up 345 down 6up 7 down 8 up set arrow to #4. And you have double checked the wiring? All tapped in except the afm signal which is cut. The pinout diagram is for an R33 so you will need to use this one:
http://www.skylinesaustralia.com/forums/post-a31087-
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5452777
sounds like your ecu can't see the afm mate
make sure you have cut the afm wire, plugged it into the safc and you have the output from the safc going back into the afm wire you cut
you splice all the wires apart from the afm one
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5452901
I found the problem... I put male female plugs on the unit 1st like it says to and the ECU already male female plugs on it so i just plugged them into what was there n cable tapped the others but whatever was in the car 1st had the plugs on backward to the manual so i had the yellow and white wire the wrong way.. All sweet and working now so now off to Protek for a tune....
Thanks heaps guys
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5453518
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
