Thats the wiring diagram that i found but it doesnt contain any settings or wiring for stagea.. it hasnt even got r34... it only goes up to r33
You will find the settings for the Laurel C34 and Skyline R33 are the same - use those as Chook says. When you have done that you should set all the knobs to zero until you can get a wideband meter or preferably have it tuned on a dyno by someone who has. For best results you should now try to track down an Apexi SITC to adjust the timing. But a Greddy E-manage would be better.
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5451685
Try reversing the toggles - it can be hard to tell whether they are supposed to be up or down. 1,2, up 345 down 6up 7 down 8 up set arrow to #4. And you have double checked the wiring? All tapped in except the afm signal which is cut. The pinout diagram is for an R33 so you will need to use this one:
http://www.skylinesaustralia.com/forums/post-a31087-
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5452777
sounds like your ecu can't see the afm mate
make sure you have cut the afm wire, plugged it into the safc and you have the output from the safc going back into the afm wire you cut
you splice all the wires apart from the afm one
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5452901
I found the problem... I put male female plugs on the unit 1st like it says to and the ECU already male female plugs on it so i just plugged them into what was there n cable tapped the others but whatever was in the car 1st had the plugs on backward to the manual so i had the yellow and white wire the wrong way.. All sweet and working now so now off to Protek for a tune....
Thanks heaps guys
https://www.sau.com.au/forums/topic/337105-stagea-safc/#findComment-5453518
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
