:flamed:
Just bought the "Handling Package" kit for $658 ;)
Will be installed at my mechanics workshop, then i will take it to get the wheel alignment.
Does the handling kit include urethane bushes and sway bars etc?
im assuming it would have to, did you get the strut brace too?
i called whiteline myself a day or 2 back. for a 33 gtst the works kit goes for about 1400 i was told, 5% off if u get it all installed at kirrawee (or whatever it is).
That said yes the kit does include cstrs and sways/strut bars
The "Handling Package" includes:
- Thicker front and rear adjustable sway bars with urethane bushes.
- Front adjustable caster urethane bushes
- Rear adjustable camber urethane bushes
Strut bar is optional in this package. Did not purchase as i already had one.
Also purchased a set of "Pinapples/Dougnuts". Not too sure exactly how to explain how these work, hopefully someone else can inform you.
easy. The 4 mounting points in the back of a Shkyrhine have soft rubber bushes which have too much movement hence you get "tramping" on heavy launches. "Pineapples" are hard polyurethane bushes which essentially squish the rubber bushes and make everything nice and tight on all four mounting points which means less movement = less tramping.
btw I thought 33's didn't tramp like 32's and s13's ?
