Hey Guys and Girls,
THAT time has come again for another Hardtuned charity cruise, and we all know cruising for a good cause is very worth while! We have been advised that its drift prac that day BUT THIS IS FOR A GOOD CAUSE and the only date we could get before the charity camper finishes.
It will be held on SUNDAY the 3rd of October. :happy:
The charity we have chosen is:
Can do 4 Kids: Can Do Caper
We are supporting 'we thought it was a disco' which is Hindmarsh Plumbing's team Can do 4 Kids campo. Our very own *EYECANDY* is a team member.
ALL the money/s raised will go towards their team at a small cost of $5 per cruise Map!
http://www.candocaper.com.au/
We will not have any letters or help with any permits for unroadworthy cars to be driven during the cruise. This is due to previous issues.
The Meet spot will be the JB HIFI on south road, melrose park (diagonal to the Castle Plaza shopping centre)
EVERYONE TO ARRIVE at 10am
and we will be leaving and beginning the cruise at 11-11.30am
Please note:
If you are 'hoon driving' or behaving in a way that puts yourself or other drivers in danger, you will not be welcome to join us and we will report you to the police.
Hoon driving is unacceptable
HOPE you ALL can make it, will hopefully be a great day with even better weather :)
and questions or queries feel free to inbox myself, Talia or Tom :(
http://hardtuned.net/forums/index.php?show...p;#entry5924539
Edited by Lil Miss 32
https://www.sau.com.au/forums/topic/337112-sa-hardtuned-charity-cruise/
  • Replies 79
Can't do it the weekend before?
I'll be a drift prac I think as car will finally be ready (I hope)
Then its too early for notice. We need to make this big as it is a charity cruise :)
there is 1 big speed bump and a shit entry into the car park. Goodluck to low car people.
:):down:
:) Wa Wa You risk driving your car anywhere you go. For all I know u could have a car crash tomorrow far out relax a bit. Its one speed hump. Years ago I had over 100 cars that went over 6 bumps and no one complained and if u knew how to drive a low car you shouldnt have a problem.
Then what about the Saterday insted of the Sunday?
If you want it to be big, booking it the same day as another car event wont help :)
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
