i just got all my front end bushes replaced by fulcrum, when he handed me my keys he said that there was a vibration above 60km/h when your cruising along, he also said he thought it was my tyres or mayb my brake discs. i have swapped the brake discs with some other ones i had here and the vibration is still there and there is a very bad shudder when you touch the brakes above 80km/h. could it be my abs stuffing up??, or my power steering??
thanks for any info
Did this problem exist before the bushes were replaced? Is everything bolted up properly?
Doubt it would be the abs or power steering. To eliminate the abs you could pull the fuse and retry. Had the wheels balanced lately? Jack up the front and check for wheel bearing play.
Do you have access to a lathe where you could measure run out on the rotors? Stockers can easily get warped with hard use. Try cleaning up the pads and ensuring there is a chamfer on the leading edge.
i cant remember if it was there before the bushes, the wheel bearing was the original reason i put it in to fulcrum, they just found lots of bent things when they were looking so i got it all replaced. tyres were replaced and balanced 2 days before the front end got re done. there is a bit of movement in the steering rack though. i could probably spin the rotors at work.
actually i just thought something. when i first noticed the shudder it was while i was heavily braking from 180 to 40 to go around a corner, can the discs have warped that easily?? doesnt solve the constant vibration but would explain the braking part.
That sounds to me like it could well have been ABS, not sure about the rest of it
I was hoping it would be something simple. I think I might take my cracked discs in and get a price on some stronger replacements. Thanks every one :)
I would say check out your tie rod ends. If you've not replaced them recently, I can guarantee it would be them. Would explain the bit of play you say you have in the steering rack.
  • 1 year later...
Quick question , slight vibration on down hill braking 70-100 ks also bit of pulsing on slower breaking up to a stop . Would this likely to be disk issues or wheel align tie rod ends or all the above ? Stegea 01 rs 4 turb
  • 3 weeks later...
Just did a run up and down green hill rd with the fam , and the pulsing under brakes is very prominent now really not good , going in tomorrow to have a chat about getting it sorted anyone got a rough est on what I should b paying for machinig discs etc also would this possibly b a abs issue thanks for any feed back.
New disks required Aps, probably best to upgrade now to the r32gtr sumitomo's for the extra 10mm disk thickness, these barges are well under-braked and the disks pay the price.
What's the going rate for replacement discs comp to the upgrade , this car is not driven hard on a regular basis so I'm not sure if it's worth it . You guys are clearly experts on these cars what do you think , also 4wd light comes on intermittently , service due very soon hopefully get these issues sorted . .
If it's just a road car and not driven that hard, I'd look at either RDA or DBA rotors. I have DBA 4000 series and they're excellent, and DBA have just released a new T2 street series that might be worth getting a price on?
PM GSLRallysport, a forum trader, and Greg will help you out.
I had aps problem and replaced front discs and pads and that made it alot better. I can still feel a slight pulsing especially under light braking, does this mean the rears also need doing? Car has hicas if that makes a difference?
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
