Hey guys...
I am an avid reader of the performance section of these forums but i find that most people serching for more RWKW's rather seconds...
My question is what would be needed to be done to a stock R33 GTS-t to produce 11's, with street tyres, and no MAJOR weight reduction.
I am looking to purchase a 33 very soon and wanting to work it acheive 12 sec 1/4's but just got curious as to what extra would be needed. I also intend on this to be a daily driver with bite.
(BTW I am aware that there are multiple ways for this to be acheived, just looking for the different methods and ideas)
Cheers
https://www.sau.com.au/forums/topic/33712-what-is-needed-for-11-sec-14/
  • Replies 50
Money.
Sorry, couldn't resist it.....
We have a full weight R34 GTT that does 11.7with 310 rwkw on Nitto radials. So do a search for how to get 300 rwkw out of an RB25DET. There would be at least 50 that I have posted to. Take your pick of methods and then stick a pair of Nittos on the back and, as long as you can drive, and the track is is good condition, an 11 is achievable.
Hope that helps
Try and do it with the stock turbo :D.
I'd be looking at BFG drag radials tyres wise and a good working over of the suspension. With BFG's you should get the 60ft down to high 1.5's / low 1.6's (like to see that out of sh*tto's). A modifed transbraked Turbo 350 auto with a 5000rpm high stall and a lower diff ratio might help too.
Hi rev, Wilson did a 1.45 on Nittos, Munroe did a 1.48 and Lee did a 1.6. I've got plenty more examples if you like. None of those were in Perth though, in fact I can't find any decent radial tyre times from Perth. Must be the track.
Just make sure you try and buy one with the basics already covered, otherwise it'll add up to "may as well just get a GTR" territory.
If you can find one with FMIC, full exhaust, boost controller, suspension, aftermarket ECU, and hopefully a few other extras for around $20k, that might save you $10k just there. That might make a budget of getting there below 35k possible.
Then your concerns will be building the internal strength of the motor, turbo and the required support systems for that. Otherwise, yeah, just find one already done .. it may be boring but it will save you a **** load of money.. over the last year or so I've seen quite a few GTS-T that will do mid-12's for $25-30k
Yeah i spose i never thought of that.
I am a huge fan of the GTS-t as a quick but non-expensive car and also has the looks. The main reason i was after a GTS-t was the rear wheel drive aspect. How hard is it to turn a GTR into rear wheel drive?
Cheers
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
