Hey guys...
I am an avid reader of the performance section of these forums but i find that most people serching for more RWKW's rather seconds...
My question is what would be needed to be done to a stock R33 GTS-t to produce 11's, with street tyres, and no MAJOR weight reduction.
I am looking to purchase a 33 very soon and wanting to work it acheive 12 sec 1/4's but just got curious as to what extra would be needed. I also intend on this to be a daily driver with bite.
(BTW I am aware that there are multiple ways for this to be acheived, just looking for the different methods and ideas)
Cheers
https://www.sau.com.au/forums/topic/33712-what-is-needed-for-11-sec-14/
  • Replies 50
Money.
Sorry, couldn't resist it.....
We have a full weight R34 GTT that does 11.7with 310 rwkw on Nitto radials. So do a search for how to get 300 rwkw out of an RB25DET. There would be at least 50 that I have posted to. Take your pick of methods and then stick a pair of Nittos on the back and, as long as you can drive, and the track is is good condition, an 11 is achievable.
Hope that helps
Try and do it with the stock turbo :D.
I'd be looking at BFG drag radials tyres wise and a good working over of the suspension. With BFG's you should get the 60ft down to high 1.5's / low 1.6's (like to see that out of sh*tto's). A modifed transbraked Turbo 350 auto with a 5000rpm high stall and a lower diff ratio might help too.
Hi rev, Wilson did a 1.45 on Nittos, Munroe did a 1.48 and Lee did a 1.6. I've got plenty more examples if you like. None of those were in Perth though, in fact I can't find any decent radial tyre times from Perth. Must be the track.
Just make sure you try and buy one with the basics already covered, otherwise it'll add up to "may as well just get a GTR" territory.
If you can find one with FMIC, full exhaust, boost controller, suspension, aftermarket ECU, and hopefully a few other extras for around $20k, that might save you $10k just there. That might make a budget of getting there below 35k possible.
Then your concerns will be building the internal strength of the motor, turbo and the required support systems for that. Otherwise, yeah, just find one already done .. it may be boring but it will save you a **** load of money.. over the last year or so I've seen quite a few GTS-T that will do mid-12's for $25-30k
Yeah i spose i never thought of that.
I am a huge fan of the GTS-t as a quick but non-expensive car and also has the looks. The main reason i was after a GTS-t was the rear wheel drive aspect. How hard is it to turn a GTR into rear wheel drive?
Cheers
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
