  • Replies 50
You can pickup an R33 GTS-t for $18k, you can also pickup an RB26DETT for about $7k so thats $25k and you got a RWD Skyline with the power of a GTR. A decent condition R33 GTR = $40k, you see what i'm talking about ? ?
With all the support systems though, it will still cost. If you are chasing around 300rwkw it can be done with an RB25 - changing the engine will only be an added cost, as you will still need all the associated support systems.
If you do go down the replace engine line though, just to go a little out of left field, RIPS is running 10s in a R32 GTS4 which hasnt been hugely modified, but has a 3L conversion. He sells rebuilt 3L conversions for around 3.5K landed in aust (not sure about duty and gst), but that is a whole lot cheaper than an RB26, and will easily support over 300rwkw with much better torque due to its stoke and the extra capacity.
If your going to go down the replace motor path, (i dont think its required, RB25DET is capable of those times)... then why not get an R32.
Cheaper initial price, slightly less weight, and has same engine options, only you will need to bin the gearbox as well.
I think the general consensus here is each engine/car combo is more than capable on the std internals with good support systems and good tuning, including suspension.
You can make power without all that, but be prepared to wear a bill if you go beyond the threshold and get detonation. It only takes that one time, then it is worth the good rebuild but you will still need the support systems and tuning.
Well a 11Sec is my goal as well and is easily achieveable with stock internals. The secret to using stock internals is more fuel!.
Here is my plan of attack.
R33
RB25L Engine / RB30 Bottom End (adds more torque and better turbo spoolup)
Greddy or Custom Plenum
Z32 AFM with Intercooler Piping
Power FC
T04E HighFlow (A/R 0.60)
HKS Cams
Ogura Flywheel
Blitz BOV (High Rev Pressure Release)
6 x 550cc Injectors
040 Bosch Fuel Pump
BRK7E Spark Plugs (copper holds boost better than any plug on the market)
Some good clutch
After all these major mods you will be in the low 12 / high 11 sec bracket.
hope this heaps, maybe ive missed something but feel free to add to the list.
cheers
ak
i've run a 12.98... now not 11 i know, far from it.
But that was on street tyres... 225's with a 2.1 60ft.
A very poor suspenson setup, the R31 IRS is a shocker for drag racing the way i have it at the moment.
And the driver aint the best :D
Not making excuses, just saying that times can be better, anyways...
I'll bet that if i had Nitto's/slicks and suspension (suspension plays a goos part)
Then then my times would be fast approaching a low 12 run. That was with 203rwkw on 13psi (non standard turbo)
My 31 weighs in pretty much the same as a 33 does so weight is the same.
With approx 240rwkw i'm confident that on slicks it would come very close to high 11's.
I've also seen RB30et's in VL's... yes they do have a weight advantage compared to a 33.
With approx 220-230rwkw break consistent very high 11's with slicks.
But are you after HIGH 11's... or Mid-low 11's.
because mid-low 11's IMO, your talking a lot more $$$.
Hi rev, Wilson did a 1.45 on Nittos, Munroe did a 1.48 and Lee did a 1.6.  I've got plenty more examples if you like.  None of those were in Perth though, in fact I can't find any decent radial tyre times from Perth.  Must be the track.
I think I might have been hasty in my generalisation. I just seem to see and hear of alot of rear wheel drive car owners unable to extract decent (for semi slick) 60ft's from the Nitto's considering how expensive they are compared to the other brands.
I've seen low 1.5's out of BFG's in rearwheel drive only cars with very modest power to weight ratio's ,unlike keir and munro's monsters :P, and fairly average suspension. For the money I still think the traditional BFG and Mickey T's offer the best bang for buck and overall performance (not sure if the nitto's last longer for road driving tho' so that might be a bonus).
Hey guys thanks for all the comments and info...
After a short think about it i am thinking if i was to go ahead i would be aiming at a more realistic time of mid to high 12's.
I really had no intention to replace the internals and money is of the esscence...
Thanks again
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
