  • Replies 50
You can pickup an R33 GTS-t for $18k, you can also pickup an RB26DETT for about $7k so thats $25k and you got a RWD Skyline with the power of a GTR. A decent condition R33 GTR = $40k, you see what i'm talking about ? ?
With all the support systems though, it will still cost. If you are chasing around 300rwkw it can be done with an RB25 - changing the engine will only be an added cost, as you will still need all the associated support systems.
If you do go down the replace engine line though, just to go a little out of left field, RIPS is running 10s in a R32 GTS4 which hasnt been hugely modified, but has a 3L conversion. He sells rebuilt 3L conversions for around 3.5K landed in aust (not sure about duty and gst), but that is a whole lot cheaper than an RB26, and will easily support over 300rwkw with much better torque due to its stoke and the extra capacity.
If your going to go down the replace motor path, (i dont think its required, RB25DET is capable of those times)... then why not get an R32.
Cheaper initial price, slightly less weight, and has same engine options, only you will need to bin the gearbox as well.
I think the general consensus here is each engine/car combo is more than capable on the std internals with good support systems and good tuning, including suspension.
You can make power without all that, but be prepared to wear a bill if you go beyond the threshold and get detonation. It only takes that one time, then it is worth the good rebuild but you will still need the support systems and tuning.
Well a 11Sec is my goal as well and is easily achieveable with stock internals. The secret to using stock internals is more fuel!.
Here is my plan of attack.
R33
RB25L Engine / RB30 Bottom End (adds more torque and better turbo spoolup)
Greddy or Custom Plenum
Z32 AFM with Intercooler Piping
Power FC
T04E HighFlow (A/R 0.60)
HKS Cams
Ogura Flywheel
Blitz BOV (High Rev Pressure Release)
6 x 550cc Injectors
040 Bosch Fuel Pump
BRK7E Spark Plugs (copper holds boost better than any plug on the market)
Some good clutch
After all these major mods you will be in the low 12 / high 11 sec bracket.
hope this heaps, maybe ive missed something but feel free to add to the list.
cheers
ak
i've run a 12.98... now not 11 i know, far from it.
But that was on street tyres... 225's with a 2.1 60ft.
A very poor suspenson setup, the R31 IRS is a shocker for drag racing the way i have it at the moment.
And the driver aint the best :D
Not making excuses, just saying that times can be better, anyways...
I'll bet that if i had Nitto's/slicks and suspension (suspension plays a goos part)
Then then my times would be fast approaching a low 12 run. That was with 203rwkw on 13psi (non standard turbo)
My 31 weighs in pretty much the same as a 33 does so weight is the same.
With approx 240rwkw i'm confident that on slicks it would come very close to high 11's.
I've also seen RB30et's in VL's... yes they do have a weight advantage compared to a 33.
With approx 220-230rwkw break consistent very high 11's with slicks.
But are you after HIGH 11's... or Mid-low 11's.
because mid-low 11's IMO, your talking a lot more $$$.
Hi rev, Wilson did a 1.45 on Nittos, Munroe did a 1.48 and Lee did a 1.6.  I've got plenty more examples if you like.  None of those were in Perth though, in fact I can't find any decent radial tyre times from Perth.  Must be the track.
I think I might have been hasty in my generalisation. I just seem to see and hear of alot of rear wheel drive car owners unable to extract decent (for semi slick) 60ft's from the Nitto's considering how expensive they are compared to the other brands.
I've seen low 1.5's out of BFG's in rearwheel drive only cars with very modest power to weight ratio's ,unlike keir and munro's monsters :P, and fairly average suspension. For the money I still think the traditional BFG and Mickey T's offer the best bang for buck and overall performance (not sure if the nitto's last longer for road driving tho' so that might be a bonus).
Hey guys thanks for all the comments and info...
After a short think about it i am thinking if i was to go ahead i would be aiming at a more realistic time of mid to high 12's.
I really had no intention to replace the internals and money is of the esscence...
Thanks again
    • Thanks for asking the question we were all thinking!
    • Does this apply if you use an aftermarket ecu as it probably doesn't have that functionality built it? (Assuming it doesn't, in my case, apexi)
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
