Hi Guys,
After a clutch for my r33 gtst.
Will need to have plenty of meat and able to handle atleast 250rwkw.
Only really need the plate as I have a nismo/exedy flywheel and pressure plate already.
In Sydney
Daniel
email or msg here
[email protected]
Cheers
Daniel
https://www.sau.com.au/forums/topic/337123-wtb-clutch-for-r33-gtst/
Hi Guys,
In Sydney
Daniel
email or msg here
[email protected]
Cheers
Daniel
whats the purpose of the car?
try KUDOS motorsports on here, they are a trader, i got my clutch kit from them, and EXEEDY ORGANIC plate one i think its called, i have 250rwkw, and it cops lots of abuse and has held up perfectly and super easy to drive with, just a fraction firmer than stock, hardly noticeable. Cheers. Andrew.
Purpose of car is to be drivable. The current clutch is gone. I don't go to track days or drift it etc.. Just everyday driving, but it has 250rwkw.
thanks for the info for KUDO's, I will look into it.
Would prefer a preloved one just to save money on going a new clutch. Just need to get car up and running.
Cheers
Daniel
not sure ur price range but i have a near new (just run in) custom made NPC clutch kit which was built to handle 500hp with tracking and drift use in mind. never got to use it at its potential as car was stripped down. super driveable (the 33 was my daily) and firm pedal feel thats not crazy stiff like my old exedy brass. will let it go $750 firm flywheel is fully machined and all, kit is ready to go and NPC gear can be vouched by heaps as one of Australia's best clutch supplier and manufacturers
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
