  • Replies 121
Possible attendance list 17-18+ cars at this stage
Me
Rb26stagea
66yostagea
Qwk32
Raysboostin
Petrodola
Hanso
Crusingfast
Pipster11
Lilcrash
Sabbai
Mattye
Japmatic
Mym35
Stagea1
Rb30dett ?
Leetom ?
Greenghost ?
Baysideblue ?
Gold Coasters - Pre/mini-meet at Coomera BP again, leaving at (I guess) 8.30am to rendezvous with the Northerners, if you're interested :)
What's the street address or nearest cross street so I can navigate there? I'm not a local as you can guess but my son is bugging me to go on the cruise.
Pacific highway heading north, opposite Dreamworld at Coomera
urzulus - i just noticed you live at springfield lakes, just out of curiosity do you live near janus grove? my sister in law lives in janus grove and ive always wondered if the stag near her was on here.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
