Ive installed mine on the 34 but for some reason, the Bass noise from the rear speakers are not hooked up. The standard rears have pretty good bass but when i installed it, there is noise but no bass. Then I somehow wired up 1 extra wire and it came on but only up to a certain level then it would cut out!??
Can anyone help? :headspin:
https://www.sau.com.au/forums/topic/33715-anyone-installed-a-stereo-in-r34/
what components have u installed? like h/u, amps, speakers, subs etc?
and where did u find this "1 extra wire" from?
and i've love to see some pics if possible - cos i just bought an R34 aswell, and will be planning to install my full sound system in very soon [hopefully]
yeah make sure all the wires are connected properly [positive-positive; negative-negative].
but i wouldnt think that phase cancellation would cause ALL the bass to 'disasppear'. but i cant think of any other reason why it mite be doing that...
no... all the wires were right... normal 4 wires for the rear speakers.. Then noticed there was absolutely no bass from the rears. Connected another wire to one of the positive or negative wire and bass came on!! But when its too loud, it cuts out??? So i have to keep it at a medium level.. Still cant work it out.
ANY IDEAS?
it sounds like youve got a wire being earthed or it's cutting out,. i had this problem once when me and a friend installed a head unit in my old vl. one of the wires was touching on another and the sound was shit and lacked heaps of bass it would also cut out going past a volume of like 10 out of 40. we found out one of the speaker wires and touching another bare wire and causing it do wierd stuff.
also the speakers will share a common wire, check you've hooked this up properly too
  • 10 months later...
You dont need to remove the centre consol.
From the begining for those that dont know...... remove the ashtray, there is a screw behind the ashtray. Now you can remove the shifter surround. It just lifts up. Now at the bottom of the stereo facia are two screws, remove them. The next part, if you use a screwdriver you can damage the dash. Use a paint scraper, put it down the crack between the dash and heater controls and wedge out the heater controls. There are two screws behind them holding the facia on. Remove the facia, unplugging anything that has to unplugged. Now unscrew the 4 screws holding the stereo brackets in. Unscrew the stereo and your new one will line up perfectly with the factory holes in the brackets. You do not need the cage so dont cut the facia and try and use it. Like every other nissan, you will be left with a small gap around the stereo. Your local audio shop may sell a trim for this. We sell them at work for $10. Or wrap a piece of velcro arouund the stereo ( just the fluffy side)
As it says in the sticky about redrilling the brackets to make that trim fit.... ignore it. A very rough and incorrect way of doing it, also very time consuming! If ya have any questions, feel free to pm me! :rofl:
BADHAB|T, Thanks for that info! :P
let me get this straight. Allyou need to remove are:
1. The gear stick surround, and
2. The stereo surround which is attached to together with the heater surround.
(Just wedge it out between the heather console and the dash surround).
Right?
NJR 34GTT : bang on man! Excellent step by step guide!
gaki : no worries dude! The vents are seperate NOT the heater controls, the heater controls are attatched to the stereo etc. (sorry for the mixup, been a while since I worked on an R34) The vents wedge out which exposes 2 screws holding the stereo facia in. Check out the link NJR posted, its easier to see it sometimes.
Oh, once you have mastered your car you will be able to do most Nissans! They all come apart in a very similar way. :D
Also, to wedge the vents out, ont use a small screwdriver as shown. You can dent and damage the dash. Use a paint scraper or something similar.
I'm about to install speakers into my car.
Do you have to remove the rear parcel shelf to do the rear speakers??
I want to fill the under side of the shelf with dacron at the same time, I'm wondering if this is going to be any good??
cheers
BASS OUT
Yes, but like every Nissan you have to remove the rear seat to be able to remove the tray (Except Nissans where the back seat folds down).
No, use proper sound deadening sheets, that fluffy stuff doesnt do nothing.
The idea is to make the tray as solid as poss to eliminate rattles but also making it more solid means less energy is wasted in vibrations, therefore making the music sound better.
Thanks Badhabit.
I have previously had the black deadening stuff in the front doors of a VS Calais and it made quite a difference.
I guess it's not a hard job to put the deadening black stuff on the back steel shelf, but how do you put it on the parcel tray itself??
Cheers
BASS OUT
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
