Hi as many know the Stagea has long brake line`s some 830mm long with 3 fixing blocks,
so iam looking at sorting some out,
i will contact few places to see what prices are + being ADR Approved ,
so if you are interested please POST & tell`s see what can be sorted out,
Cheer`s Chuckie.
Maltech do them but the ones they sent me were a little short and I only just got them to fit.. They would need another original set for a template to make sure they are right.
yes have STOCK SET SO NOWORRIES,
Arent the lines are the same with the R33s? I was being told that for mine (260rs) they are the same as the R33GTRs. and the clutch lines too. Im interested in one if the price is right.
Good New`s I have sorted someone to Make LINE`S will be ADR & legal,
Just waiting on one side made up & will trial fit next week & then get some Photo`s & cost`s SET,
Cheer`s Chuckie.
Yours is a 260RS, Yudy, so you're lucky enough to have the R33 GTR brakes as standard. The RS-Four's had 2-piston fronts and 1-piston rears with different fittings... :P
Cheer`s Chuckie.
Hey chuckie , just want to check about the braided lines , will you be getting them makd them up as totally standard or will they be set up for GTR brakes , iE - GTR callipers to Stagea original body brake line ? have seen some lines that have a nut fixing at both ends and multiple options for various fixings for calliper and body brake line , would it be something similar and would the long brake line have the brackets already fitted ? cheers all .
Yours is a 260RS, Yudy, so you're lucky enough to have the R33 GTR brakes as standard. The RS-Four's had 2-piston fronts and 1-piston rears with different fittings... :D
ok cool Nick. I think from other thread its says stageas rs4s fronts are GTRs lines and the rears are GTST or soemthing. Will you guys be doing a clutch lines as well? :down: . Good to see a senior member still around nick :P
ALL LINE`S will be for STANDARD SETUP,
I have kept then as Standard as possible,
short line to caliper, hard line around hud as STOCK.
Then iam looking opions on rest,
should have more info next week & some PHOTO`S of what i have,
GUY`S sorry but iam only looking at STOCK S2 Brake line`s ,if you want other fitting`s then you shall need to PM me if your wanting some other bit`s done (if i can help i will)
Cheer`s Chuckie.
Ok so have had some LINE`S made,post-36964-1286190545_thumb.jpgpost-36964-1286192052_thumb.jpg
these use HARD LINE on HUB,so it is fixed ,so you will need to remove it from stock set up.
i am having another set made one lenght that will use P clip,to attach it around HUB ,as few have asked about RS260 lines i can get other end`s put online`s,so if you would be interested PM me.i need some PHOTO`S of RS260 setup so those looking for them PM me your LINE SETUP.
hope to have other line`s by WED,
When i have them i will post some more detailed Photo`s ,these are LEGAL ADR APPROVED ,
NO Price yet
Cheer`s Chuckie
Ok i have Got 2 set`s of LINE`S MADE UP ,i will fit them up to my car to make sure they fit right,
i shall then sort out PRICE & COST OF POSTAGE,
Cheer`s Chuckie.
conceptua_performance_tuning on ebay are making me a set ( x6 hoses ) to fit the GTS calliper - to a 1996 series 1 Stagea RS4 (not 2WD but they can make up a set) , braided blue , Aussie , UK and German approved , price was 84 pomey pounds but that was to the UK , gonna take 2 weeks to get but wanted a colour that was not made up , will put up shots of pipes when they get here and further bla bla when fitted and tried ,
OK SO THEY ARRIVED AND ARE THE OTHER OPTION FROM CHUCKIE`S , BEING THAT THEY ARE SET UP FOR THE GTR BRAKE CALLIPERS ! , WILL BE FITTED ON FRIDAY ALONG WITH THE BIGGER DISCS AND SAID GTR BRAKE CALLIPERS , PRETTY SURE THAT CHUCKIE`S FABRICATOR COULD DO THE SAME JOB , SO ITS JUST COST , FOR THAT CONTACT :- conceptua_performance_tuning - on ebay, WILL GIVE YOU THE DIMENSIONS AND FITMENTS OF THE DISC`S IF THEY FIT NEXT WEEK
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
