Anyone seen any? I've seen 2... and here they are :D
these are not by me
This ones by a guy named illracer - pretty bloody good, eh ? :thumbsup:
org:
chop:
look everyone... an intercooler
and this ones by a guy named ran
org:
chop:
if you've seen any, post em up :)
https://www.sau.com.au/forums/topic/33717-photoshopped-g35s/
  • 1 month later...
That red one is sick, but you ghuys dont have G35's in australia???
In 12 months there'll be at least 2 *V35 Skyline Coupe 350GTs* (as opposed to the Infiniti G35 - lefthand drive version) in Australia for sure... I'm exporting them.
https://www.sau.com.au/forums/topic/33717-photoshopped-g35s/#findComment-755102
The Skyline Coupe 350GT (and the 350GT Premium) is the only grade of Skyline Coupe available. AT or MT, with 17" wheels (350GT) or 18" wheels + Brembo brakes (350GT Premium), I think the V35 is more a "Sporty" specced car than the luxury style G35... different specs for different markets... although this is the first "Skyline" to be sold in the US, Nissan (Infiniti) could of put a microwave in there and it probably wouldn't have hurt sales.
https://www.sau.com.au/forums/topic/33717-photoshopped-g35s/#findComment-755224
