Calling all SAU Gold Coast residents!
Drag Combat is on Saturday 21 February at Willowbank Raceway.
I was thinking we should meet up somewhere early in the day and cruise up as a group. How does BP Coomera @ 8.30am for 9am departure sound? Anybody reckon we should leave earlier?
The cost to spectate is $30. So start saving now. :) FREE parking is available or you can pay $8 for "premier" parking.
It will be a full day event. I believe the gates open at 8am with racing finishing around 4-5pm.
Last years Drag Combat was awesome... Don't miss it this year!
https://www.sau.com.au/forums/topic/33719-gold-coast-to-drag-combat-adventure/
i'm in it, last year was so packed, just abit dissapointed from the short cut we've taken through the back, cause when i got home and opened the bonnet all i could see is RED sand. i will definitely will pay the $8 prem parking :) that would be cool to see all our crs parked next to each other, would be the biggest attraction there........Yeee Ha... :headspin:
Pred: Cause Brisbane residents are weird :D Just kidding!
Your more than welcome to come as well as any other Brissy residents. I just figured most of the Brissy people would come out Ipswich Rd rather than backtracking down the M1.
Maybe we should stop at Redbank plaza and meet up with Brissy guys before continuing along to Willowbank?
The $8 premier parking isn't worth it. It's no different to the normal parking except it's on the other side of the fence and the thieves don't have to walk as far.
I dont think I'll be taking my car out. We'll take brutis out I think.
Hahahaha
Anyway I will be a drag combat a little earlier me thinks, am swinging spanners for GTR_Cam trying to get some good times out the newly tuned 33...
Yeah heat can be a bit of a bummer......but a bit of prep time makes all the diff, big sunshade, lightweight seat, sunblock and a couple of eskies full of ice and cold drinks in the boot ...... think of the poor competitors in the staging lanes !!! and finally....this IS Queensland. ..... Still hope to see you there
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
