Hey guyz, I have a soundstream 2 channel Amp [260W] and i used to run my subwoofer off it.. But recently i have removed my subwoofer and still have the amp in the car, i will not be putting my sub back so i was wondering whether i could connect 2 speakers to the Amp thats already in the car and would it make a difference...
And if i should connect the amp which speakers should i connect it to...
Another thing i wanted to know,i am planning on doing a bit of sound deadning to my car but was thinking of only doing the front doors, what do u guyz recommend is the most important 1st...
Cheers!!
https://www.sau.com.au/forums/topic/337217-need-to-connect-amp-to-speakers/
I'm surprised you could effectively run a sub off a 2 channel amp with that sort of output. Depending on what sort of speakers you have in the car I would generally recommend wiring the amp to the front speakers. My setup just runs a 4 channel Alpine amp bridged to 2 channels and only powering a good pair of front speakers with crossovers and tweeters then I have a monoblock running 2 x 12 alpine's in the boot and the sound is near perfect, not sure about how it sounds in the back of the car but had no complaints so far and considering its my car and im usually the one driving it I figure it needs to sound best for me..
Big thing to think about is if you are running the front or front and rear just off the deck they are probably getting a feed of 50W max so if they are decent speakers they are probably massively underpowered and could sound a lot clearer and nicer and be able to handle alot higher volume off an amp.
A good test if you dont wanna run all the cable and shit through the car is just wire it 'outside' the car and see if you're happy with the output then go ahead with it.
Need advice or a hand mate gimme a yell, not an audio expert but wired all my cars myself and I got a 34gtt also.
cheers,
Steve
Well im guessing the Car is still on Stock speakers.... Front and back... Yea i thought it would get clearer... So can i connect it to only the front speakers or can i connect the rears and front speakers to the amp...
Im considering on chaning the speakers,but that might be a while so for now i just wanted a bit more clarity than wats there...
Wer r u from btw? U think id be able to do it myself, i really dont know anyhting about connecting systems... :)
I'm in Perth mate.. umm from memory when I took out the stock speakers in my r34 they werent anything special so I'm not sure how much more power they can handle.. you could connect just the front or just the back technically this is 2-Channel (I believe).. I suppose you MIGHT be able to put left back and front together to left on the amp and right front and back together and do the same.. Don't know how effective this would be and you would lose the features of the deck and being able to tune it properly, fade it from front to rear speaker etc.
Umm.. Yeh you could probably do it yourself.. I taught myself, its frustrating but rewarding if it works out.. The biggest thing for you would be deciding where to put the amp.. In the car might be easier but I dont like the idea of an amp on my floor in the car or under the seat.. So my amps are in my boot which means I had to run wires from (in my case) Cable from the battery through the firewall under the carpet and the back seat and into the boot. Cable from the deck to the boot and cable from the boot to the front doors...
Oh an another tip, get decent quality wires don't get budget stuff it will cause you more headaches. Also try and run the speaker/amp wires down the OPPOSITE side of the car to your power cable. Generally speaking audio cabling is shielded but I found in my old car I used to get buzzing because I had wired them on the same side due to lazyness Lulz..
Any questions man ask away, like I said I'm far from an expert but I've received compliments on the sound of my system and I enjoy it which is the main thing.
-Steve
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
