Hi there , i have just bought a 1999 Nissan skyline R32 GTE, at idle the revs hunt from300 to 900, nd it has a constant eratic miss fire at idle,, when you on the road and accelerating , it has a flat spot , but never in the same spot ???? what could be causing the problem ??? i cleaned the AAc valve and it sorted the problem for a short while ???? but its back now ???
https://www.sau.com.au/forums/topic/337224-idle-hunting/
start with a couple basic things and see if these help. ive bought cars with the same problem and its always been something simple like this.....
try changing the air filter sounds like it could be hunting for air (or remove the air filter to see if that makes a difference)
check your spark plugs they could just be dirty or faulty
also try some injector clean fuel treatment sometimes that helps
and check for vacuum leaks
https://www.sau.com.au/forums/topic/337224-idle-hunting/#findComment-5461253
  • 3 months later...
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
