Well the aussies general rule is to tune rbs to a full load afr of 12 and then tweak ign timing to suit for max power where as the japs throw in a shit load of fuel eg 10.5-10.0(keeping in mind that their pump is 100+) and then throw in a shit load of timing on top of that..
I know there must be "tuners" out there who may have experimented with both methods whether it be professionals or diy-ers but......
Which method is actually better??? There must be pros and cons to each?!?
The way i see it is that the Japs method may be safer in that they dump a shit load of fuel as extra protection and then wind in extra timing to make power,the down side being a higher cost at the pump .....
I mean with their 100+ octane you would think that there is no reason to run that rich.
But does this equate to the aussies method of leaning it out some(12.0) and not throwing in as much ign timing???
I have always had the impression that changes in ign timing is what really makes torque/power and afr was secondary...so therefore running a little richer will always be better in that u can throw in more timing hence making more safe power....
I know its kind of ironic starting this discussion here with no japs to defend themselves but still would like to hear different opinions....
Would have love to see dyno sheets of one of those big shot Jap tuning shops against Aus finest on the same vehicle :)
https://www.sau.com.au/forums/topic/337236-tuning-afrs/
Took one afr of e70 out on the dyno and made 15-20kw more, that would be safer than adding 20kw of timing I would have thought, not to mention cheaper to run. Street tunes will always be a compromise I guess.
I also heard of some Japanese tuners predominantly using exhaust temp gauges. I noticed with the ethanol I am still under 600 degrees at the turbine exit so this method may not work, surely this wouldnt be smart as exhaust temps would change depending on ambient temperature and engine loads wouldnt they?
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453043
Where's the evidence to say that australian and japanese tuners always tune in this way? It doesn't seem like it's something you can generalise.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453048
If u do some reading and watch some dyno sheets on here u can easily see a pattern and every single Mines/blitz/pfc tune i've seen out of Japlan supports this as well
I have noticed similar patterns, Impul seem to tune for 11:1 afr from what I have seen. My tuner aims for 12:1 at wot.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453081
Mines and Blitz "chip/flash" ECU's sadly do not count.
They are nothing more than a typical mass produced tune. They are not specific and run rich on purpose.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453126
Tuning rich at WOT is not really going to affect your everyday fuel consumption and if you're tracking an RB of any sort petrol is the least of your worries! Keeping the engine alive is the number 1 priority for most!
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453327
Ahhhhh....That make sense but i've also seen a few pfc with full tunes ie including low load areas, with rich as high load mapping
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453716
He has a point, most cars you see running in videos in Japan blow 10afr worth of smoke and they all seem to be traveling at a great amount of knots. (correct me if i am wrong with this please)
But what we do not know or see is how how many engine failures they have there. Engines can be purchased aplenty to be replaced when one lets go, why not tune it on the ragged edge and feed lots of timing into it if its not going to send you bankrupt if you blow a engine or 2 while you are chasing that quarter mile target ??
can just imagine going through Maccas Drive through there, would you like a rb25 with your order? lol
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453860
The Japs know what they are doing.....i mean they made the shit to start with.
There must be engine failures of course but check out how many skylines get shipped worldwide some stock some with all kinds of goodies and they are still mostly in good working order for us to trash
Have u ever experimented with one of these rich ass tunes Anthony?
Would be interesting to have an idea as to how much timing can be added with running say 10.5 as compared to 12.0
Dynos here suck....no afr readout on the graph
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453861
If they're running less than 11:1 I see it as a bandaid attempt to address exhaust temps. The fuel is acting as a cooling medium - for anyone who watched the F1 cars of the turbo era, on qualifying trim they would blow plumes of black smoke, bit like when you watch a jet plane on takeoff. Same approach just to try and avoid a mechanical failure.
But you're then putting so much fuel into the cylinder that it HAS to be super advanced just to try and burn the fuel load.
I've seen a car on the dyno just ramping up to full load with 10.5:1 AFR and the engine was just hesitating like all get-out. With conventional ignition map the poor thing just wouldn't run right.
The other issue would be a tendency to wash down the bores and promote rapid/excessive wear. If they have money to burn for pull-downs and its all about that last tenth on the track I can understand but not otherwise.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453862
Agreed. Its just a waste of fuel. Heaps of fuel and heaps of ignition or less fuel and less ignition to give a similar result.
Maybe the japs run absolutely stupid amounts of boost and they just dump heaps of fuel to suit.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5453884
the "flashed ecu's" aren't always just off the shelf tunes - some of the big workshops will use the standard ECU just like a remap.
Not sure the reason why some of the top workshops do this, maybe they feel that with their builds and their tunes, they don't usually have problems and so won't let people fiddle. Or they just want to lock their customers in to their workshop.
i wonder if they all have different software packages or what they use to turn the standard ECU into something that can be flashed.
maybe all just nistune remaps :D
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5454419
years ago everyone wanted to add more fuel to their engine, know it seems we want to run them leaner.
I have read many articles were japs tune by exhaust temp only an not afrs, im sure they have their reasons for doing this thou.
would be good to see someone dyno same car at rich setting with lots ignition then the way we tend to do it and see ramp/power differences !
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5454496
As others have said, i don't think that you can conclude anything for what is essentially a "mail order" tune. Due to the fact they aren't a tune specific to any engine they can't be as "on the edge" as other tunes that are done on the car that will be running the tune.
Personally i think that MBT tuning will be the way of the future in terms of timing as the results are better and generally they are safer as "less/ideal" timing is used. The only down side is the cost at the moment due to the dyno time needed.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5454583
exhaust temps are mainly used between individual cylinders to make sure that one or more cylinders arent running leaner than the others.
a leaner cylinder will run hotter and if a hotter cylinder is found that cylinder can be richened up to match the rest.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5454667
I have run cars up on the dyno that have showed 10.5 afr's during tuning and have not had misfire or any problems with the run. You can run them that rich.
As for feeding timing into a engine that is running mid 10 afr's I have not done this yet. Never needed to. On my own car I run 11.1 afr atm and seems to be making healthy power with moderate ignition timing, its not advanced i just like to run my engine that way for insurance.
as a rule for customers cars i never go over 12 unless its a stockish car running low boost, then it will see 12.2 12.3.......
also if they are using really rich mixtures for a band aid for exhaust temp, who says the timing is too advanced? remember retarded ignition advance causes higher exhaust temp compared to a advanced tune.
Maybe they are chucking in a stupid amount of boost and running the timing very retarted and using the fuel to cool it down?
I would like to see some power fc maps of highly tuned cars to look into this further....
What the japs are really doing? we do not know... I would love to go there personally to check it out.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5454719
some of the big workshops will use the standard ECU as THE tuning ECU. They will tune it to the specific build/engine. Yes people like Mines etc have ones you can buy off the shelf, but they will also use the standard ECU (modified somehow) for their builds as well. So if you got a workshop built car with a workshop flashed ECU, that wouldn't be an off the shelf item. It would have fully customised maps just like any aftermarket one would have.
which isn't the silly given the context, as the standard ECU obviously does things well like cold start, idle etc. I believe the newer Evo owners tend to keep the stock ECU and get it flashed. There are benefits sometimes to keeping factory items, albeit tweaked a little :cool:
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5455050
which isn't the silly given the context, as the standard ECU obviously does things well like cold start, idle etc. I believe the newer Evo owners tend to keep the stock ECU and get it flashed. There are benefits sometimes to keeping factory items, albeit tweaked a little :thumbsup:
Yes they work fine for the Japanese tuning shops but they are not a good buy second hand if you don't have any way of altering the tune.
https://www.sau.com.au/forums/topic/337236-tuning-afrs/#findComment-5455587
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
