Ok, what is this?
I pulled dash apart to swap my bose cd changer over after it failed as most do. somewhere along the line my air con got disrupted and now only blows hot air unless i switch it to manual mode and the face setting at 18degrees....
Only other things changed are z-tube / pop charger and plenum but they were not on before this started happening.
The only thing not plugged back in is this rubber band thing that i remember coming off under the glove box area off the dash... Any suggestions???
No responses... I fixed it and here is the solution in case anyone else needs help.
Under the steering wheel remove the screw near bonnet release. Pull kick board down and its a little plug that is causing all the issues!
Step 1: http://img138.imageshack.us/img138/390/stickitkh5.jpg
Step 2: http://img175.imageshack.us/img175/8452/incabinfilteroj5.jpg
Step 3: http://img166.imageshack.us/img166/2533/harnessig4.jpg
That fixed it, these are not my pics by the way but docron1 from G35 forum ( must more info than here fyi) - cheers !
Now only to find out what the rubber band thing is for... Any clues?
I have had a pretty good look thru the workshop manual for the infiniti in the aircon system. Looks to be pretty much the same system and I cannot find anything in the blow-up diagrams that resembles this part
Only thing I can think of is that it is a low pressure seal of some sort for the aircon ducting
Thanks for the help ! Air con is ok now but i got no idea what its for. I remember it falling and thinking i must remember thats where it came from...
Frickin forgot...
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
