Ok, what is this?
I pulled dash apart to swap my bose cd changer over after it failed as most do. somewhere along the line my air con got disrupted and now only blows hot air unless i switch it to manual mode and the face setting at 18degrees....
Only other things changed are z-tube / pop charger and plenum but they were not on before this started happening.
The only thing not plugged back in is this rubber band thing that i remember coming off under the glove box area off the dash... Any suggestions???
No responses... I fixed it and here is the solution in case anyone else needs help.
Under the steering wheel remove the screw near bonnet release. Pull kick board down and its a little plug that is causing all the issues!
Step 1: http://img138.imageshack.us/img138/390/stickitkh5.jpg
Step 2: http://img175.imageshack.us/img175/8452/incabinfilteroj5.jpg
Step 3: http://img166.imageshack.us/img166/2533/harnessig4.jpg
That fixed it, these are not my pics by the way but docron1 from G35 forum ( must more info than here fyi) - cheers !
Now only to find out what the rubber band thing is for... Any clues?
I have had a pretty good look thru the workshop manual for the infiniti in the aircon system. Looks to be pretty much the same system and I cannot find anything in the blow-up diagrams that resembles this part
Only thing I can think of is that it is a low pressure seal of some sort for the aircon ducting
Thanks for the help ! Air con is ok now but i got no idea what its for. I remember it falling and thinking i must remember thats where it came from...
Frickin forgot...
