I was watching some clips on U-Tube this morning that my partner had left open for me to have a look at, and it was called "How to get out of a speeding fine" (
) and it got me thinking How have you got out of a ticket?
My most shamed attempt of getting out a ticket was being pulled over in my BMW for having a cracked break/tail light lens (not only was it cracked it would collect condensation in there that lead to there being water sloshing around in there) my break light was also frequently out because like most other things on the car it was falling apart, I can't remember if my break light was out at the time (In the end we fixed it was a cable tie and a length of gal wire) so this it how it went
Officer: Evening Miss, are you aware you have a crack in your tail light? *Officer pulls out a fine pad*
Me: Do I? *Playing dumb and looking shocked* Oh, No Officer I didn't. Do you mind if I hop out and have a look?
Officer: That's fine,it's the drivers side
*Walks to back of car* *Opens boot* *Leans into boot and plays with some wires* By this stage I knew the cop had taken the bait was staring at my arse *closes boot and returns to car*
Officer: I suppose I can let you go with a warning this time but make sure you get it fixed.
Me: Yeah sure Officer. Bye
I have also shamelessly told a cop that he's blue uniform went excellent with his eyes, and asked another officer if he works out. I only have 2 points left so I got excellent at kissing arse when I was driving that car
https://www.sau.com.au/forums/topic/337268-ways-to-get-out-of-fines/
  • Replies 55
That wasn't suppose to sound like me boasting about getting out of a ticket, I was actually asking if anyone else had got out of tickets. That video on You-Tube just got me thinking about some of the odd ways people get out of tickets
I dont quite understand the situation, would help if you reinacted the event and posted step by step pics.........
hah ha thats mint, love it. dont know if it would work for me though...
ive never tried to get out any fines ive been given... all one of them :D but my friend simon tried the 'ol crying gig, same thing as das kamu, copper got embarrassed and sent him home hah ha. only thing lost was pride :D
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
