My external wastegate is mounted under the turbo and the heat is destroying normal rubber/silicone vac lines (manifold and turbo are ceramic coated, dump and front pipes are fibreglass wrapped).
What kind of hose do i need to be using to give them a chance against the heat? (wastegate is the synchronic 50mm so it has 3 pressure/vac lines)
https://www.sau.com.au/forums/topic/337270-external-wastegate-vac-lines/
What kind of hose do i need to be using to give them a chance agains the heat? (wastegate is the synchronic 50mm so it has 3 pressure/vac lines)
My waste gate lines are made from a hi temp braied hose. Same stuff they use for brake lines i believe.
Got any spare exhaust wrap lying around?
I wrapped my o2 sensor's wiring in fiberglass wrap (lengthways, i.e. use 1m of wrap for 1m of line/wire.) and its been fine thus far! 30,000kms in...
i had the lines wrapped in fibreglass wrap, they go hard and brittle then start leaking pressure and the boost goes through the roof.
as in braided teflon lines?
loving the truckers flexible pipe.
have you tried making a heat shield for the wastegate,
synapse recommend keeping that sort of heat away from the gate anyway so maybe you should get some xr6 turbo heat shielding and shield the gate and lines.
can you run the lines down and either under the sump or around the back of the motor rather than up through the manifold?
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
