Alright was looking at my car today and found some bird decided to have a stomach ache over bits of my car.
These are those small worm-looking stains that are yellow and LEAVE a yellow stain on my white paint!
I imagine a lot of us here have white Skylines so would have the same problem?
How have you guys gotten bird doo stains off?
I have tried using Armour-all Goo-remover, put on polish then taken it off, Meguires Scratch X...list is growing...pain is growing.
Thanks for any help
https://www.sau.com.au/forums/topic/337287-bird-poo-stains-how-to-remove/
When a radiator boils over, the water temp doesn't affect the paint.
When you park the car in the hot sun and the temp gets up to 100 degrees it doesn't ruin the paint either.
So yes... have a go...
If your paint needs compounding later on,...
Wash > High Quality Polish > Sealant > Canauba Wax > more resistant to bird poo stain
x3 on the hot hot water.
Obviously the sooner the better. As soon as you see some rush in and boil the jug!
Takes it off no troubles at all. Then just give it a wipe and a touch up with polish if need be.
  • 8 months later...
sorry to revive an old thread.
did the boiling water end up working? a birds decided to drop its guts over the car. tried a cut and polish around the area but its still stuck there like glue.
Like the others said it won't hurt your paint, so just try it
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
