Hey all. I am the proud new owner of a 260RS Autech. It was delivered to my house yesterday. Some of you may of seen it on carsales.com but here is a few pics of it.
69,000ks on the clock with a few mods.
Keen to hear what younthink of it.
https://www.sau.com.au/forums/topic/337289-i-just-bought-a-260rs-autech/
Yeah it is a ex powerplay car. I hope it is A1 and not had too harder life as it has done a couple a track days but on the other hand it seems to of been well maintained. I have a big pile of recipts for it detailing what he spent on it on upkeep. I generally do not buy already modified cars but have wanted a 260RS for sometime now and couldnt go past this one! As for it being fast... blody hell its fast. But I can only get the boost to go as high as 7psi even after playin with the adjustable boost dial!?? Was told by ex owner it can go as high as 23psi!
Dunno how I will go with rego as I have not had to do it yet. The ex owner recons he had no problem. But we'll see...
I am not to keen on the gauges that have been slapped on the dash board so may look at relocating them of atleast getting them to sit better on the dash. Its a terrible job someone has done putting them on there. As for the roll cage. It has had alot of time spent on its instalation as it is all hidden from outside of the car except for when you are looking head on into the front window.
Its got a heap of mods. I will have to find the list of them and post em up at a later date for you.
Well done on the purchase mate, i seen this car parked outside of autosalon last year in homebush and had to stop and drool for a few minutes it's very nice, was the previous owner in Pyrmont ? if it was him then he looks after all his stagea's well, if im not mistakes he owns 3 260's ? anyway mate sweet ride best of luck with it.
That looks a lot like one of Powerplays customers cars.
If it is, it's easily one of if not the quickest stags in the country
Seen this on their website a few years back. Nice. and packing heat. Deserves some track duties. Australias first 260RS/GTR front end conversion - i think i just jizzed in my pants, lol. Wind that boost up mate.
Edited by dirtyRS4
OK. Here is the list of mods that are scribbled down on a bit of a$ paper from the last owner:
A very rare Genuine 1998 AUTECH 260RS over 550 HP. 5 Speed MANUAL.
Features include: R33 GTR Engine.
VOLK TE37 BLACK 17" Alloys.
N1 R34 GTR Turbos.
HKS Dump Pipes.
Greddy Piping Kit.
NEW Exedy Triple Plate Clutch.
N1 Apexi fully adjustable suspension (coil over i belive...).
Mines airflow meters.
HKS Spark Plugs.
Braided brake lines.
Front dampers.
Rimax Clear cam cover.
Oversized injecters & fuel rail.
Adjustable cam gears.
HKS Front mount intercooler.
HKS 24 Row oil Coiler.
Aftermarket exhaust (not sure what diametre as yet).
Engine Dampener.
Front and rear torsion bars.
Brake Booster.
Relocated Oil Filter.
Full Roll Cage.
Blitz Turbo Timer.
Blitz Boost controller.
GReddy gauges, oil pressure, fuel pressure, Oil temp, exhaust temp + more.
This is one awesome car, which can run up to 1.6 Bar.
Endless Brake Pads all round.
Recaro Front seats.
There maybe more. As I dont think that even the owner exactley everything that has been done to this car. I am also pretty sure he mentioned MOST of this was done by Mines in Japan. Could this be true?
My main question for you all is... What on this car is defectable? And what can be passed by an engineer so it aint defectable?
Anything you have to say, both good and bad is much appreciated.
sounds like a weapon!
in answer to your question, of what is defectable and what isn't - it's all very subjective and dependant on the mood of the cop who pulls you over (and i guess also the reason he pulled you over!).
in terms of what is going to prevent you from getting it roadworthy for registration, i think the cage might present an issue if it isn't fully padded - do some reading on DOTARS. a reasonably on the level tester will just be looking for the obvious and well known stuff like noise, number of induction modifications (if its got a cooler, no pod filter), ride height, gauges on the dash etc. almost anything can be engineered, if you're happy to spend the time and money to satisfy requirements - but most people find its easier to remove and replace later.
in terms of what is defectable, i can only comment from my knowledge in vic (and it is by no means bible) - but i'll go through your list.....
N1 R34 GTR Turbos - should be ok as look same as stock, just hi flowed and wheeled.
HKS Dump Pipes - no problem
Greddy Piping Kit - no problem so long as all factory fittings retained for vacuum and returns
NEW Exedy Triple Plate Clutch - no problem
N1 Apexi fully adjustable suspension (coil over i belive...) - subjective, coilovers are a grey area, but if ride height is 100mm min then shouldn't give them a reason to look.
Mines airflow meters - touch and go - EPA might ping it, but an average traffic cop wont unless it's got MINES written all over it, but as a rule, you can't switch AFM's.
HKS Spark Plugs - no prob
Braided brake lines. - problem. unless they're approved.
Front dampers - coilovers? no problem anyway
Rimax Clear cam cover - no probs
Oversized injecters & fuel rail - problem. EPA would spot it, and maybe even TMU. but for RWC, you'll pass.
Adjustable cam gears - problem, especially behind clear covers. maybe through a stock cover on and problem solved,
HKS Front mount intercooler - no prob, so long as no body work has been cut to fit.
HKS 24 Row oil Coiler. - no problem
Aftermarket exhaust (not sure what diametre as yet) - so long as under dB limit and has cat converter
Engine Dampener. - no problem
Front and rear torsion bars. - no prob
Brake Booster. - no prob
Relocated Oil Filter. - no prob
Full Roll Cage. - potential prob if not padded correctly or if interferes with passengers
Blitz Turbo Timer. - apparantly these are illegal
Blitz Boost controller. - problem if found
GReddy gauges, oil pressure, fuel pressure, Oil temp, exhaust temp + more. - if they're all electronic, and not placed in the 'immediate crash zone' on the dash, then not a prob.
Endless Brake Pads all round - no prob
Recaro Front seats - should be no prob
Also noticed a Cusco oil catch can sitting in the engine bay, and an oil filter relocator.. don't think either of these is defectable (unless the catch can vents to atmosphere), but you can add them to your list of mods.
Thanks for your reply. See my replies to your answers in red below.
Shouls be ok?
Can see them easily anyhow. Too much pipe work cover em.
Where do I measure this 100mm to and from?
Cant see Mines written on em anywhere. Not even sure if they are still stock.
Really? Surely they are better than stock!?
Bugger.
Adjustable cam gears - problem, especially behind clear covers. maybe through a stock cover on and problem solved.
Really? Why?
Looks to me as though nothing has been cut and it is a good install
Aftermarket exhaust (not sure what diametre as yet) - so long as under dB limit and has cat converter.
Exhaust is actually pretty quiet which I am happy about. Dont "think" it has a cat converter...
Definately would like to get this engineered
Whats the problem with these?
Blitz Boost controller. - problem if found\
Would like to look into this more. Can do a much better job of installing these myself.
Yep. These will be right.
I think these may need to be engineered
Blow off valve is no where to be seen...? (can anyone tell me exactely where to look?). And it is also fairly quiet, which is also good.
As both the exhaust and BOV are quiet, and the car looks nice, simple and stock from the outside with the 17 inch Volks (not 20inch chromies), I feel pretty sure I "should not" have too much strife with this car. I live in a country town with a population of 25,000 though so there aint too many schmick cars about...
Thanks for your answer SMOKEY ol' mate.
Edited by Global_Warmer
If you get pinged for all of those things you'll be in a fair bit of trouble, but it's not likely to happen. The average traffic cop might notice a few of those things, but not all of them.
Best bet for a car as modded as this though is to get a full engineers report, that can be enough to stop the cops bothering with any defects.
I'll try to answer some of your questions
100mm rule means the lowest point of the car must be over 100mm high. I think this includes bodywork, i.e sideskirts or front bar, but not 100% on that.
Brake lines have to be ADR approved, by law. Just the way it is
Not having a cat converter will get you sent straight to EPA, which can cause major headaches. If you don't have one then get a highflow cat put in there. Easy to see if you have one or not, get under the car and take a look at the exhaust, the cat will be just after the front pipe leading down from the engine bay.
From what I have been told, turbo timer isn't actually illegal, however leaving your car running while you are not in it is illegal. Although you could still be defected for it. I don't have one myself, just let the car idle for a minute or two after driving hard, or take it easy for the last 5 minutes before you park the car.
The seats may be a problem if the rails don't meet ADR's. I know BRIDE rails don't meet ADR's, because they have never gone through the testing process over here. Don't know if that is the same with Recaro rails.
I'm guessing with the BOV, but if it is in the same position as on GTR's, it will be on your intercooler piping before the intake plenum, hidden down by the front bar.
Living in a country town can be a bonus, I'm currently in Bathurst (home of the v8 bogan), had my car for over a year and haven't had any police dramas so far, knock on wood. They don't seem to care as much about defecting out here as they do in Sydney
no dramas mate, like i said - not gospel, just info i've picked up from 15 years on car forums .......oh and a few trips out to macleoud for EPA testing.......
rims are ok. 17s are same size as standard, so can't see it being an issue at all, just so long as your tyres are load rated correctly, and not overly stretched.
braided brake lines, yes technically they are better - but there is also a lot of dodgy ebay bought braided lines available - i can show you a thread that has pictures of a catastrophic failure of braided lines during a stop from 250km/h on a track day - the car was saved by a combination of downshifting and handbrake application. brakes are not something to mess with! but given the money spent on the rest of this build, i'd say they are legit. might be worth checking them though.
100mm is measured from the absoloute lowest point on the car. usually it is the catalytic convertor.
turbo timers are apparantly illegal because they leave the car running whilst unattended. worst case scenario - you roll your car through the window of a busy cafe - it is leaking fuel like madbut also, and you are unconscious and trapped in the car, but a someone is able to pull the keys out of the ignition - but the car keeps running........
boost controllers are illegal because they effectively have the capability to alter the fuel mixture of the car. any device that leads to an alteration to a richer fuel mixture (as measured by a Co2 meter) is an EPA fail. just one of those blanket rules. these are an easy one for cops to spot, as people usually put them in easy to reach places for adjustment reasons. just try hide it as best you can. its just a blanket rule that applies from everything as simple as bleed valves, EBCs, SAFCs, powerFCs, all the way up to stand alone ECUS.
you should be right if you behave yourself in a small town - but get on the wrong side of the cops and they'll ping you ever time! in fact, i'd probably prefer to be in a large city !!
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
