oh and in regards to the patrol pathfinder, etc block head combine, i was a bit off :cool:
you use the rb30 block, rb26 head and nissan Navara or pathfinder (forgot which one exactly, but a bit of google will surely ifnd it) pistons, conrods and crank.
they will make the engine to a 3.2 or 3.4l engine.
Care to elaborate on exactly how this "might" be possible? Larger pistons dont solve the problem of the block being thin in the bore. Fact is, you can not bore past 88mm with an RB block (all of them) before the cylinder thicknesses get below 2mm.
You can use that bore size if you wanted to grout fill the block as well, but thats not going to work for a street engine, as you would need to do a complete fill to get the strength in the block where it's needed (at the top 1-2" of the cylinder). Even then, an 88m bore is only 3.1lt anyway with an 85mm stroke.
Stroker crankshafts like the one that Spool are developing, combined with a sleeved block (to allow an 88mm bore) are about the only way you can get anywhere near 3.4lt.
3.2lt is easier to achieve. A 6" chevy rod with 1.88" big ends on an offset ground 87mm RB30 crank, with an 87.5mm piston will get you a 3.15lt. 87.5 is about as large as I've "read about" people running without sleeving (not my recommendation though). And you'd want to be dam sure about your tune, so you dont go splitting the thin bores. Having an engine that can only be tuned to 7/10ths is pretty pointless in my opinion.
  • Replies 66
Posted Images
im not 100% on how it all got done, i didnt do it, the tuner doing my mates skyline did it, i will be going there tomorrow and ill see if i can get a couple of answers.
could be that conrods are shorter or pistons have a differnent top. in which case youll have really low compression but more litres. or even if the crank has a longer stroke/ turning circle. but ill ask him how the fkuk he did that all tomorrow.
since i havent done it i can only speak from word of mouth.
but on another note, i say buy a 24u block and keep your skyline a skyline not a hybrid "Commoline"
i know this thread is about the engine, but is there a car involved??? i kinda got lost after a while....
Well I haven't bought the car yet, like I said it will definitely be within 1-2 weeks. I just need info on this because the Skyline hasn't got alot of forums around, they're either Japanese or in the UK. This site seems to be solid. I only want 3/3.1 litres but if 3.4 is possible then the more the merrier. However I do want the engine to keep that "RBness" about it.
hay dude, whats this patrol block ur talking about, i think the old ones do run rb30's
mine will handle 1000hp and cost me 10k, how does the patrol block make it a 3.5litre, this is interesting...
Pretty sure the patrol block he means is the RD28 diesel block.
There is a 26/28 R33 in the latest Zoom mag with 937rwhp and has run a 8.3 @ 163mph
This thread gives me the shits, bigtime.
Buy the car. Take to someone who has done the rb30 conversion before who is local to you. Pay money. Done.
Mine is a 3L. Makes enough power to scare other built GTR owners. Still revs like an rb26, if you Fu(k it up it won't rev.
I agree Steve. This thread is almost a waste. Why would you want to buy an already well done 400kw R34 GTR [ACCESS] and then go for an RB30 stroker?
Anyway, don't waste your time, I am buying it as a daily driver. :)
Exactly Steve, thats why I popped my head in here..... but I gave up, too much cluelessness here for me.
not sure which Patrol motor you're referring to, RB30S (I have one) is an R31 motor with a carburettor (and 4wd sump, also takes ~6l oil). RB28 or TB42?
Try driving a reletively stock one IMO, then decide whether you want to go more displacement, or bigger turbos etc.
I think I'll be getting the OS Giken 3.15 motor, it seems to be coming from a solid company and I calculated it, I could make it work into the budget. Now because this thing is so expensive I want the best tuner in the country. I would be willing to go interstate for a tune if its necessary. Does anyone know a good tuner with a good workshop?
If you are so concerned about displacement, get a Clubsport!!!
or alternatively:
M3 is 3.2 or 4.5 (?) if it's the V8
2.6x1.7 turbo multiplication as per motorsport regs = 4.42, so basically the RB26 is equivelant to an NA 4.4l, but is even easier to get HP out of. Seriously get the car, drive it for a bit, play with what you get then decide what you want to improve. if it is STRICTLY a road car what the F do you need more than 300hp for? even my stock R32 with a pair of -7s is quicker that all bar the top Porsches/Ferraris/Lambos etc to 100... The way you are talking I would personally be suggesting maybe this
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
