hi guys, need help to find out what the hells going on with my engine... lol, car is a r33 gtst s2 latly the car has been running fine but sometimes and for the last week im having engine problems. if and when the car wants to start, it will only rev to 2500 rpm.
somedays it will do this for 5 min to 30 min but pritty much this last week its been doing this,
can anyone help me with this issue???
have you tried anything to fix it yet?
save people suggesting things you have already tried
nah mate havent done anything yet, just seeing if anyone has had this problem first so i can do it myself... would of taking it to a machanic but dont have time... and being a sunday n all... got a perfictly good garage, was just gonna start cleaning out some hoses and sences, but if ive got a good idea on where to start that would be good too.
What do you mean by won't rev past that, does it struggle when it gets to 2500 or does it try to stall or what?
Maybe a boost leak somewhere, causing overfuelling?
Hook up a boost gauge to it and see what is going on with the turbo. It sounds like it has something to do with it given it's happening around the point where boost comes on.
nah the car works fine, it doesnt struggle at all it just wont rev past 2500rpm. just cuts out like its restricting itself. like while driving i have to keep it under 2500, it such a pain in the ass... lol
it use to do this a few times every cople of months but its been a week non stop now, and it sometime takes for ever to start, from 5 to 30 min...
What happens if you accelerate real slowly past 2500, i.e. no boosting of the turbo at all? Can it be done? It sounds like a fuelling supply issue to me thus far...need more symptoms to diagnose further.
sounds like it's in limp mode. this can be caused by a dodgy afm. try unplugging the afm and see if it makes any difference to how the car runs.
also try disconnecting the battery to reset the ecu. might also be worth checking the fault codes.
nothing happends it just stops at 2500 while accelerating and still makes boost, well a lil... but if im in 5th gear doing 80kpm (top speed 90kpm when this happends) and drop it down a gear or to 2nd it will still deaccelerate through the revs and with the foot to the floor it will only come back when it comes to or under 2500. it just restricts itself from going past 2500.
ill give the battary ago to see if the resets it... will let you know...
yer nah the car is still doing it, tried everything....
ill just take it to an auto machanic. and see what they come up with.
+1. Complete AFM failure/ failing is most likely to cause this.
ok i tryed the fault codes and its the afm thats playing up, i think theres a wire some where in the loom thats loose or needs replaceing. cus i fiddled around with the loom to the afm and o2 censor, and finaly after 2 weeks the car started to rum fine again but only to where i was going, and onec i started it up again, it started doing the same 2500rpm bullshit.... damn.... but does anyone know any good way of cleaning out a afm?
it may be a damaged solder inside the unit. if you happen to know someone with a s2 r33 who will let you borrow the AFM to try out is going to be the best solution.
also don't bother looking at the o2 sensor when trying to diagnose the problem. it does next to nothing and the car can be driven without it even being hooked up (i did for a few months). your fuel economy just won't be as good.
spray contact cleaner on the filamint in the afm n blow on it with a compressor, not to hard thou. this usually improves fuel economy too. give that a go n c if it works. also it takes a few re starts of the car to reset the error codes in the ecu so maybe just reset it first to c if it goes away. if this doesnt work borrow an airflow meter off someone n see if it fixes the problem if not check the wiring. also buy a rb25 workshop manual on ebay. makes things way easier.
  • 2 months later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
