Got some aftermarket performance parts removed from a R33 GTST. All top of the range high quality parts. The prices are fairly firm.
1. Nismo / Rays LM GT2 Wheels. 18"X8" Fronts & 18"X9" Rears GTST Offset. Excellent condition, gunmetal grey centres. One wheel is missing 1 allen key bolt.
Tyres: Fronts - Goldenbridge GB700 235/40/R18 in as new condition. Rears - Nankang Ultra Sport NS-11 265/35/R18 @ 50% tread. - $1800
http://i160.photobucket.com/albums/t177/Sh...00/100_1121.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1117.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1111.jpg
2. A'PEXi Power FC with Hand controller & boost controller kit to suit RB25DET - Wont Seperate - $1500
http://i160.photobucket.com/albums/t177/Sh...00/100_1152.jpg
3. Garrett GT35R Turbo + Ceramic Coating, HKS Cast Low Mount Manifold + Ceramic Coating, Manifold Heatshield, Braided oil & Water lines with fittings, TiAL 44mm Wastegate, Dump/Front Pipe & O2 Sensor, Piping with GTR BOV, A’pexi POD filter and Z32 Air Flow meter & wiring harness.
Set-up was installed on a RB25/30DET so will be direct fitment onto another 25/30 or will need an adjustment made to the Dump/front pipe on a standard RB25.
Turbo - Front housing .60AR Rear housing .82AR. - Won't Seperat - Whole Package $2500.
http://i160.photobucket.com/albums/t177/Sh...00/100_1169.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1176.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1172.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1183.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1186.jpg
4. Genuine Greddy Forward Facing Inlet Plenum, Greddy Throttle body adaptor, RB25DET Throttle body, Piping, Alloy windscreen washer bottle and longer Throttle cable - Won't seperate - $1000
http://i160.photobucket.com/albums/t177/Sh...00/100_1208.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1212.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1211.jpg
5. Nismo Fuel Pump - $250
http://i160.photobucket.com/albums/t177/Sh...00/100_1188.jpg
6. D1 Front Mount Polished Intercooler & Immediate Piping - $300
http://i160.photobucket.com/albums/t177/Sh...00/100_1161.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1164.jpg
7. Splitfire Coilpacks - To suit S2 RB25DET - $350
http://i160.photobucket.com/albums/t177/Sh...00/100_1197.jpg
8. Fujitsubo Catback Exhaust - $250
http://i160.photobucket.com/albums/t177/Sh...00/100_1235.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1244.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1238.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1243.jpg
9. 3" Metal Catco Cat 5" Wide Body - $150
http://i160.photobucket.com/albums/t177/Sh...00/100_1191.jpg
10. Ross Metal Jacket Harmonic Balancer - Will be removed later this week when i get a puller - $400
http://i160.photobucket.com/albums/t177/Sh...00/100_1167.jpg
11. OS Giken STR2CD Twin Plate Clutch - Clutch plates measure at 4.5mm on vernier calipers - $500
http://i160.photobucket.com/albums/t177/Sh...00/100_1103.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1109.jpg
12. Nismo 320km/h Dash Cluster - Showing 31,500K's - $450
http://i160.photobucket.com/albums/t177/Sh...00/100_1146.jpg
13. Works bell steering wheel and boss kit - $150
http://i160.photobucket.com/albums/t177/Sh...00/100_1151.jpg
14. MTX Audio Road Thunder RT404 4 Channel amp with metal mounting plate to bolt to fuel tank opening screws in R33 Rear boot & MTX Sub with box - Sits tight in drivers side of R33 boot - $150
http://i160.photobucket.com/albums/t177/Sh...00/100_1157.jpg
http://i160.photobucket.com/albums/t177/Sh...00/100_1159.jpg
15. A'pexi lightweight front strutbrace - $80
http://i160.photobucket.com/albums/t177/Sh...00/100_1214.jpg
Standard Parts:
16. RB25DET S2 Engine loom - Has had AAC Valve wires extended - $100
17. Alternator - $100
http://i160.photobucket.com/albums/t177/Sh...00/100_1204.jpg
18. Aircon Pump - $80
http://i160.photobucket.com/albums/t177/Sh...00/100_1205.jpg
19. Power Steering Pump - $100
http://i160.photobucket.com/albums/t177/Sh...00/100_1202.jpg
20. AAC Valve - $40
21. Steering Rack - $100
http://i160.photobucket.com/albums/t177/Sh...00/100_1224.jpg
22. Tail Shaft - $100
23. Genuine Skyline Floormats - $80
Will post items that can be sent via Auspost otherwise is Pick-up only from Emerald, Victoria.
Contact me in this thread or through PM. If you have Under 10 posts E-mail me at [email protected].
https://www.sau.com.au/forums/topic/337362-performance-parts-sale-r33/
hay buddy
wanna sell the gate, turbo, lines and dump pipe only (dont need the rest at all)
pm me if ur keen with a price.
how much power did u make and at what boost bro
hay buddy
Not seperating anything from the package. Cheers
AUD, which is basically the same as CAD at the moment.
hey im interested in ur cat converter have u got any other pics of it cause it looks like the flanges are altinated and not straight so i bit worried might not fit my exhaust
Sent you a PM
got ur pm but i cant pm back yet havent got 10 posts did u weld the flanges on it or did it come with them and what car did the cat come off i just wanna make sure it would fit mine b4 i decide on anythin
PM Sent
SOLD:
Nismo Fuel Pump
Almost got money together for clutch via seapost will get back to u shortly, do not have 10 posts yet but am working on it so I can pm you. 2.6% extra is no prob as well as you need to cover your costs :laugh:
