Hey all,
This is just an EOI topic atm to see if anyone is interested and to get an approximate price, I will put a price up and feel free to comment what you think it is worth (dont be a douche) Thanks. Pictures on request!
1997 R33 S2 GTS-t Manual 146,000 km/s Silver
Services every 5000km/s or less by BoostWorx (best in Adelaide IMO)
Mods:
Garret GT2540 Ball-bearing turbo
Hybrid FMIC (brand new >100km's)
300ZX Modded computer and tuned
3" Turbo Back Exhaust
17" Rims with tyres 90% front and 70% rear
Mongoose 3 Immobilizer Alarm
Blitz BOV
Apexi EL2 Boost Gauge
Turbosmart E-Boost Street 40psi model
Heavy Duty Clutch
Suspension has been modified to be stiffer but not by me so not sure what was done exactly.
Pioneer OEL Deck
New AFM fitted (2nd hand)
Rocker Cover Gasket Replaced (to fix a old leak)
ABS Relay Replaced
Steering just redone, new tie rod ends, new hub on right wheel etc
Basically I have fixed everything on this car and done it up, there is nothing to do. Ignore the missing paint on the front bar, it used to have a crap Nismo lip on it which cracked and fell off but how it was fitted it pulled paint off. I am getting it repainted next week.
Unfortunately I forgot to get Boostworx to print off the power output but at 15psi it was 220.7RWkW's (295RWHP) but I would recommend if you are lookign at this car seriously ring them and they will tell you I have spared no expense on it and it has been serviced before 5000 ever time.
Interior is near on immaculate and outside is very good.
Looking for $16k or swaps, pref R34 any model really.
Thanks for looking
More available on request!
Bad Points:
Driver seat has a rip on the side (trying to fix this before i sell it)
hows about swapping for my twin turbo soarer ??
check my topics, and if you were keen i'd be happy to meet you halfway
Hey mate, really nice soarer but I have never really been a fan of them sorry mate. GL with the sale tho!
Will also consider swaps for a V8, BA XR8 UTE or Sedan or VY. PM or reply for any swaps
just a quick note bud, you can buy these for a lot less it may be a very clean example but unless it has 250KW+ with supportings people may not spend that much. i have a 96 S2 with only minor things wrong with it,full body kit, all engineered, making about 200KW and i paid alot less. question is: how much do you want to sell it and how long do you have?
My two coin
GL Bud
Cam
My two coin
GL Bud
Cam
Honestly I dont expect to get $16.5k especially on the Skylines Australia forums where you can find some really good bargains but that said I don't need to sell for any reason so its more of a swap thread than a sale but yeh you can get S2 alot cheaper but you will encounter alot of problems not necessarily big ones but wear and tear such as paint, tie rod ends, tires, pads, service, disks cracked, oil leaks, wheel bearings, interior blemishes, dodge wiring, wheel well rust, missing ashtray, missing plastic wheel guards, boost leaks, ignition coils, turbo bearing etc etc.
This list goes on thats all I can think of off the top of my head but I have spent thousands and thousands (ask my mechanic) on this car and there is literally nothing to spend that's why im not selling it at rock bottom price.
Thanks for the comment tho. Cheers
if you put it for around the 13 - mark it will sell bro , theres 33s with 260rw going for 10 , in average cond tho
Yeh defiantly man but I dont need the money I just thought I would post to see if anyone would be interested in swapping mainly, I am actually really happy with the car and really like it. There is nothing wrong with the car at all, so I am going to get rid of it for a lower price because I just dont need to.
  • 1 month later...
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
